Ecm
Old Jan 26, 2011 | 06:05 PM
  #31
jcahicks's Avatar
jcahicks
When I open the drain valve behind the fuel filter it runs fuel out. Is that an indication the fuel pump is running? I get gray smoke out of the tail pipe when I turn it over.I'm not home yet so I cant check the IPR but I will later tonight.
Old Jan 27, 2011 | 12:53 PM
  #32
jcahicks's Avatar
jcahicks
Ok I checked the IPR it has the tin nut on the end of it. No wires coming out right?
Old Jan 27, 2011 | 04:37 PM
  #33
zx250's Avatar
zx250
Of the next Riffraff East
Should be a plug on the top side.
Old Jan 27, 2011 | 05:56 PM
  #34
jcahicks's Avatar
jcahicks
Ok yes there is a plug on the top side.
Old Jan 27, 2011 | 06:14 PM
  #35
zx250's Avatar
zx250
And that plug has wires going to it.
Old Jan 27, 2011 | 06:20 PM
  #36
jcahicks's Avatar
jcahicks
Yep and I have 11.14 volts at the plug. ON the Gpr I have 12.57 volts going in and 11.49 coming out with the key on.
Old Jan 27, 2011 | 06:33 PM
  #37
zx250's Avatar
zx250
Sounds like your batteries are good. You have fuel and you know that it is fuel and not gas or water. Your oil level is up to par. Are you getting any smoke when cranking? Your dash lights all are working. Is your tach moving while cranking? Just trying to catch back up and make sure we are on the same page.
Old Jan 27, 2011 | 07:14 PM
  #38
jcahicks's Avatar
jcahicks
I just checked it is fuel coming out the drain, I do get grey smoke while cranking, oil level is at the top of the safe operating marks on the dipstick,The tack does not move while cranking, my cps is grey the mechanic I had it to replaced it and still no change. I think the old cps was black with a gold piece of metal on it.
Old Jan 27, 2011 | 07:33 PM
  #39
BigAlsPSD's Avatar
BigAlsPSD
With the '02 your tach wont move, so the belief with the new CPS is that is good as well, with the smoke it seems as though your injectors are being commanded to fire. Will it start with the block heater plugged in for a few hours? This could lead me to believe injectors are worn out, as mine would not start without being plugged in even during the "cool" summer nights.
Old Jan 27, 2011 | 07:35 PM
  #40
jcahicks's Avatar
jcahicks
Dont have a block heater.
Old Jan 27, 2011 | 07:49 PM
  #41
BigAlsPSD's Avatar
BigAlsPSD
Did you remove it?
Old Jan 27, 2011 | 07:55 PM
  #42
jcahicks's Avatar
jcahicks
No I bought the truck this way. I just went and looked and I dont see a cord hanging down anywhere under the truck. and nothing laying up in the engine comartment that I can see.
Old Jan 27, 2011 | 07:57 PM
  #43
zx250's Avatar
zx250
I will be lying in the front bumper on the drivers side and it can be hard to see. probably easier to find by feeling.
  #44
BigAlsPSD's Avatar
BigAlsPSD
Near the oil filter there should be an orange cord, follow that to the bumper area usually around the tow hooks, there should be a plug clipped or tied up somewhere around there? Drivers side headlight area possibly too. The cord will change from orange to black somewhere along the way.
Old Jan 27, 2011 | 08:05 PM
  #45
jcahicks's Avatar
jcahicks
Boy do I feel stupid there it is tucked away nice and neat. Ive had the truck for 5 years and never knew it was there. I just thought that wire by the oil filter was just another wire.
