ford explorer
Old Jan 22, 2011 | 10:51 PM
crowhawk's Avatar
crowhawk
ford explorer
my explorer seems to idle to low and ruff idle i replaced the depfi sensor. could someone tell me what might be wrong
Old Jan 23, 2011 | 01:09 AM
shorod's Avatar
shorod
Welcome to the forum!
What year is your Explorer and which engine does it have? When is the last time the engine has had a tune up (spark plugs, plug wires, fuel filter, air filter, etc.)? Have you checked for pending diagnostic codes? Did this just start happening after the weather got cold? Have you checked for vacuum leaks?
-Rod
Old Jan 23, 2011 | 10:10 PM
crowhawk's Avatar
crowhawk
it is a 1994 has 239,000 miles on it i put plugs in it but i have not changed the fuel filter yet i can't get the lines to disconect the people don't know what kind of disconect tool to use
Old Jan 24, 2011 | 08:58 AM
MCDavis's Avatar
MCDavis
Does the 1994 have an Idle Air Control (IAC)? This is a common problem with the second gen engines, and I cannot recall if the first gen had them or not.
The IAC gets carbon build up in it and will often times not open, causing a low or rough idle.
Old Jan 24, 2011 | 12:39 PM
crowhawk's Avatar
crowhawk
i am not sure also could u tell me what size wrench i need to get the egr valve tube losen up so i can take it off and clean the valve and the tube and intake holes. where would the iac be located at
Old Jan 24, 2011 | 01:02 PM
MCDavis's Avatar
MCDavis
Go to Google images and type in "Ford Explorer IAC". You'll get a few hundred images. It should be located near the throttle body. It is a metal cylinder attached to a flange. I could not find a great image to put on here for you, sorry.
There is an explorer forum, not on FTE, that has a pile of how to's on this. You'll end up coming across some of them in your search.
I used to belong to that other forum when I owned my '99 XLT V8.
Can't help you on the wrench size for the EGR.
shortbed97
Jan 29, 2012 11:40 AM
jay576
Feb 19, 2011 10:11 AM
designbc
Sep 3, 2003 09:59 PM
BroncoScott
Oct 23, 2002 11:47 AM
CobraXP
Apr 22, 2002 06:52 PM
