2002 transfercase not fully diengaging
Old Jan 22, 2011 | 08:49 PM
8720fordfan's Avatar
8720fordfan
I recently removed the front driveshaft to do somework on it and when I was tightening all the bolts I heard something snap from around the transfer case. I checked all the bolts they are tight. The problem I have is now it seems like the transfer case is not fully disengaging when taking out of 4wd drive, and I have a noticable noise from the transfer case area. If I reverse about 10-15 and go forward it seems fine and the noise goes away.
Is there any plastic pieces that I may have snapped or maybe something with the vacuum pump on the transfer case?
The truck has a Superlift lift kit with driveshaft recommend by them.
Old Jan 22, 2011 | 11:38 PM
Dutter's Avatar
Dutter
Well as far as that noise you hear when you go out of 4x4 is normal for automatic hubs and when u go in reverse it gos away also normal, If you do any kind of wheelen id convert them to manual like i did, because iv broken a pair of those hubs and once i went to manual everything was solid and no more having to back up to get them to disengage
DAVID'S97F250HD
Mar 7, 2024 08:04 PM
Tim Shultz
Sep 28, 2013 09:57 PM
SuperDutyScaler
May 18, 2011 11:54 AM
jlsk8ter
Oct 31, 2010 08:01 AM
Jimbo302
Jan 20, 2005 01:17 PM
