dash removal
Old Jan 22, 2011 | 05:48 PM
rickybobby1977's Avatar
rickybobby1977
dash removal
i have a '77 f-150. i Want to put a stereo in it. Does any one have tips to take the dash off without tearing it up? Also the dash panel where the stereo goes has already been cut. The hole is 1/4" too big. Anybody hade any ideas?
Old Jan 22, 2011 | 06:01 PM
bucks77ford's Avatar
bucks77ford
The bezel comes off pretty easy. Just remove the wiper ****, light switch *** and the screws and it pops off easily. To patch the hole a bit, you could use some thin plexi glass or lexan to make a patch, paint it black and put the stereo in.
Old Jan 22, 2011 | 06:06 PM
rickybobby1977
Not to argue but, I broke the ***** off my '73 F-350 flatbed. Is there a trick? This truck has been sitting for 5 years
Old Jan 22, 2011 | 06:09 PM
OrFordGuy's Avatar
OrFordGuy
what i did with mine is replace the bezel with a fresh one, weld in a patch panel to replace the cut up peice where the original radio and heater control mount..then cut it fit thenew radio... i've noticed that the original panels when cut leave no or little material to support the radio...then install radio...
Old Jan 22, 2011 | 06:15 PM
rickybobby1977
Do you have any pics of yor fix? I do better with visuals
Old Jan 22, 2011 | 06:55 PM
bucks77ford
check this thread out on **** removal.
https://www.ford-trucks.com/forums/5...b-removal.html
Old Jan 22, 2011 | 10:56 PM
OrFordGuy's Avatar
OrFordGuy
no pics currently, and not ful member yet so i can't post any...sorry, when i tear the bronco down for paint i'll illistrate it andshould be prenium member by then..
scott-86
Feb 8, 2017 10:34 PM
70FE250
May 2, 2016 10:17 PM
F350fireman
Oct 21, 2012 08:33 PM
O SEA D
May 30, 2010 03:33 AM
RecklessAbandon
Apr 8, 2003 09:01 AM
