Head Stud queastion
Old Jan 22, 2011 | 02:49 PM
cmurphy72's Avatar
cmurphy72
Head Stud queastion
I have to have the bed plate re-sealed and am going to have the studs done while the engine is out. The tech said he could do the studs for about $300.00 more in labor and I can get the studs. I am also going to have him do the trubo drain valve and the blue spring upgrade.
I have 2 questions:
1. How much should I expect to pay to have the heads machined?
2. What else should I have done while the engine is out?
07 6.0 cc srw KR with only 32K miles.
This forum is awesome and I have already learned a lot and also provided some insight. I check it everyday.
Old Jan 22, 2011 | 08:22 PM
2006lariat's Avatar
2006lariat
Some on here say the heads dont need machined. Some say they do.
The heads on the 6.0l are very tight from the factory, meaning you can run into clearance issues if you machine them! You tech should be more than helpful on what they recommend!
Old Jan 23, 2011 | 12:49 PM
holdendaniels's Avatar
holdendaniels
Do the HPOP STC Flex kit upgrade as well
Old Jan 23, 2011 | 04:40 PM
lenzhotrod's Avatar
lenzhotrod
Is he doing new headgaskets also or trying to do the studs by removing bolts one at a time?
Old Jan 23, 2011 | 07:00 PM
cmurphy72's Avatar
cmurphy72
He will be doing the head gaskets as well and that's why I was wondering how much to pay for having the heads machined.
Old Jan 23, 2011 | 08:44 PM
rdunagan's Avatar
rdunagan
my opinion i would have them machined because when you take the heads off they become uneven and then you will have the leaking problem again. my machine shop cost about 400 when i did mine but i also had a bad head. i think normally its like 600 down here in texas. and yes do the hpop fittings as well. also egr delete or egr billet cooler. do those now!!!!!
krys4990
2004 - 2008 F150
13
Sep 7, 2020 09:10 AM
expolice
Feb 21, 2013 08:00 PM
LRSTony
Nov 30, 2011 06:33 PM
yellow72f100
Jul 22, 2008 08:20 AM
jamies460
19
Jun 7, 2008 10:52 PM
