2004 F250 6.0 Diesel choking out, blowing smoke
After the truck gets warmed up it starts to hesitate and when at stop lights when ready to accelerate it chokes out but doesn't die. I have changed out fuel filters and the air filter and it still is choking out. Blows a lot of white smoke once it starts to accelerate. Any suggestion on what needs to be replaced?
It's easy to do, just hard to pull that little sucker out.
Undo both bolts. Twist until the eyes the bolts go through are accessible, then I tied some heavy duty wire into each eye and made a loop. Took a piece of re-bar through the loop and used the alternator as a pry location and pulled up hard and quick.
In the picture, you can just see the EGR valve
Links:
Diesel Technician Society
This next one has part numbers for you.
Links:
i made a boomerang out of a metal broom handle. LMAO, i underestimated the power of those little o-rings
rogerlwii
20
06-12-2016 09:09 AM
Buyerz
09-20-2015 06:15 AM
JoeHarbourJets
05-17-2011 03:03 PM
