Is it Original
Jan 22, 2011 | 02:38 PM
Is it Original
Hi fellas, just wondering how does one know if the front fenders, hood ect. are original Ford oem parts or a way to know if they are aftermarket ?
Jan 22, 2011 | 03:41 PM
What I have read on here and been told that any OEM part should be stamped. Look at the inside of the fender, should see a stamp
Jan 22, 2011 | 05:53 PM
all factory ford parts are stamped with the ford oval there small and usally put in inconspicaus placs, look carefully..
Jan 22, 2011 | 06:04 PM
The fender stamps are on the top of the fender. I haven't found the hood one yet, but I'm sure it's there.
Jan 22, 2011 | 07:42 PM
Hi guys, i've looked on ma truck b4 did not see anything on the exterior of the panels, then i picked up 2 fenders at the local yard still nothin, did not look on the inner part of the fenders that i picked up, ill look at that tamarrow, Thanks for the feedback
Jan 22, 2011 | 07:52 PM
The stamps on the top of the fenders are small and tricky to see. If you can't find them, then they are most likely aftermarket fenders. I have yet to find a stamping on inner fenders.
Jan 22, 2011 | 08:03 PM
Well i have four fenders ta look at and hope i can find at least one stamp, so they are really that hard ta see/find ?
Jan 22, 2011 | 08:30 PM
i found the oval stamp easier to see form the inside ,on the fender it is the top bolt rail near the center
Reason: adding picture
