fuse panel
Old Jan 22, 2011 | 01:10 PM
mfeveleth's Avatar
mfeveleth
fuse panel
I have a 1978 f250. the fuse panel cover is not there and I am have a hard time reading what fuse is what. I could use some help as I am having trouble with the brake lights. I want to make sure I have power from the fuse panel to the brake peddle switch. Thanks.
Old Feb 21, 2011 | 07:15 PM
dogmantra's Avatar
dogmantra
BUMP
similar issue with illegible fuse block
Old Feb 22, 2011 | 05:11 AM
fordjake's Avatar
fordjake
ive had simillar problems from my 78 f-150 so i just bought a new fuse panel and went with blade fuses. after a day of rewiring the whole chasis i had no problems except the reverse light. if all else fails run a single wire to your lights like a jumper and check your light holder. it wont tell you where the prblem is but im good with electric and ill let you know later the color code. if im not mistaken it should be the same all the way to your brake limit switch and adjustin that might be your whole prob just let me know.
Old Feb 22, 2011 | 05:56 AM
fordjake's Avatar
fordjake
wire confusion
I will be working on my truck first thing at 7 am in west Tn go vols. I will give you what my truck has asap.
1978-BBB
Oct 30, 2011 05:34 PM
renchr56
Dec 28, 2009 09:41 AM
lud04X
May 18, 2008 11:56 AM
loveoldtrux
Oct 3, 2006 11:08 AM
62stepside
Electrical Systems/Wiring
Apr 19, 2001 08:45 AM
