Whistling sound while accelerating
Old Jan 21, 2011 | 11:29 AM
bighunt34's Avatar
bighunt34
It started this winter and only does it when it's pretty damn cold - say below 20 degrees. Only does it when on the gas and varies from quite loud to not too bad. Any thoughts?
Old Jan 21, 2011 | 11:43 AM
Brack1's Avatar
Brack1
Perhaps someone, in the night, installed a turbocharger. We should all be so lucky!
But seriously, mine makes a squeak when it's cold. I haven't put any time into tracking it down, but my first thought is one of those dummy pulleys or tensioner.
Old Jan 21, 2011 | 11:49 AM
bighunt34's Avatar
bighunt34
I found some other posts on this and apparently this is not an uncommon problem. Most I've been reading say alternator but there are some mentioning pulley's as well.
Mine will go away after the truck warms up IF it's not very cold - this morning I had it for the whole drive but it was 6 degrees out too....
Old Jan 21, 2011 | 12:13 PM
hcbph's Avatar
hcbph
Whistle
My alternator kind of howls when it's cold for a minute or two but quits when it's run a minute or two. For a whistle though, my T-Bird will do that any time if a Fram air filter is in it. Never found out why as it seems to measure accurately and it doesn't do it with Motorcraft air filters. Might be worth a look.
Paul
Old Jan 21, 2011 | 05:06 PM
bighunt34's Avatar
bighunt34
pretty sure my last air filter was a Wix. And not all that long ago. Can't swear that this didn't start before or after the Wix install. Had to be semi close though as I only started noticing the sound this winter and I know I put a new filter in last oil change which was almost 3k ago which would have been about 2-3 months ago.....
hmmmmmm.....
Jerry Chaney
Nov 15, 2016 07:54 AM
dessmo
Feb 14, 2016 11:01 AM
DidieX
Nov 13, 2015 01:03 PM
2006powerstroke90
Sep 14, 2011 10:20 PM
Rus01
Mar 26, 2011 02:23 PM
