What flywheel do I have?
I was checking the clutch travel while I was under there also. If I jam the clutch pedal to the floor and crawl under the truck there is only about a 1/16 or an inch play between the clutch material and the flywheel... is that normal? Looks like the clutch thickness is about 3/8 of an inch. I've read lot's of threads on here, including DMF for dummies, but I've not seen any of this in person off of a truck. Anyone know the total thickness of clutch material on a new clutch? Would appreciate any info. Thanks. Josh
Personally, I'd tell you to throw in a new clutch just to make it all good to go so you have no worries. Just do it when you got it all down and then you dont have to worry about it.
Let me look if i have any side view pictures of the DMF.
If your interested in a new clutch though, check out Valair. Some of the best customer service I've ever seen, and a USA Made product as well. Call and talk to Dan or Gary, and you can tell them I sent you if you want, Just tell them William from Michigan.
Reminds me, I haven't talked to Dan in a while... Hmm.
Their organic replacement clutches are rated really good HP wise, and their performance clutches are even more awesome.
Travis is running a Full Ceramic, and I'm running a Ceramic/Kevlar. They also have a Full Kevlar clutch, which I will install on any DD truck I get from now on. The kevlar is super tough and smooth as silk, but grips.
Just waiting for these pictures to upload.....
haha. Its like watching paint dry.
Alright, here we go.
You can see here on the DMF, there is a bit of a gap by the penny. Thats where they separate.
here is the DMF installed with PP in the truck.
You can see mine is nice and oily.
Well, was.
This is the most side view picture i have, and its kinda blury where it needs to be, i was trying to take wear pictures for valair to make sure everything was good.
I thought I had some issues. I didn't install the washers on the FlyWheel by accident thinking they were for the PP. So I thought my flywheel was loose, hard to tell with gear rollover.
Oh, thats another way to tell if you have an SMF.
Do you have any gear rollover?
Is there a drone sound at idle when you dont have the clutch pushed in?
Thanks for the photos Tayln, the one with the penny you pointed out is the most obvious that there is a gap there. Mine doesn't have a gap there as far as I can tell so I'm 95% sure it's an SMF. I don't notice any noise from gear rollover though??? I've decided the best thing is to just get everything out on the ground so I can look it over. Since I've not had it apart before, I want to be sure and get what I need. I enjoyed your write up on the DMF by the way.
Josh
Mine has pretty much went away completely, and not everyone reports gear rollover from SMF conversion.
Its just the parts inside rattling from the engine vibrations.
All depends, you might not get it with a valair either.
Most amusing though that a lot of guys try to trash valair cause of the rollover
Tubs, you woudlnt' want a DMF anyways. they are destine to fail.
The flywheel also costs 2 to 3 times as much as its better SMF counterpart.
That is if you can find a DMF thats new.
Oh well, should have the rebuilt transmission and new clutch in there by next week. Thanks for the replies.
That's funny.
