Heater Problems
Old Jan 20, 2011 | 04:48 PM
Brad SS's Avatar
Brad SS
Heater Problems
Hello. I've got a 2004 Ex 6.0 Heater and blower are working, but the buttons to direct the heat are not. Can not seem to get any heat to flow down low. I've looked through some of the posts, but didn't see this particular issue where power is getting to the unit, but the buttons aren't working. Any advice would be apporeciated to get me started.
Thanks, Brad
Old Jan 20, 2011 | 04:59 PM
jh818's Avatar
jh818
Check vacuum lines to see if there's a leak.
Old Jan 20, 2011 | 07:13 PM
cay5628's Avatar
cay5628
Mine got stuck on high fan blowing heat only thrugh all of the vents/ducts.
I had to replace the whole control. It shorted out something in there. Worked fine ever since.
Old Jan 20, 2011 | 07:26 PM
Scottwoo's Avatar
Scottwoo
Cay, mines doing the exact same thing. What did that control cost you if you dont mind me asking? Thanks, scott w.
Old Jan 20, 2011 | 11:12 PM
Brad SS's Avatar
Brad SS
Thanks JH - vacuum line had a leak under the hood. Now I've got to go take care of the mouse problem in the shop. Wonder what else got chewed on.
Thanks again.
Brad
Old Jan 20, 2011 | 11:22 PM
jh818's Avatar
jh818
Thanks again.
Brad
You're welcome. Did that fix the problem?
JSP2
37
Feb 18, 2024 09:57 PM
Yamaha0219
Feb 15, 2021 03:53 PM
Brad Brown
Dec 17, 2016 10:36 AM
conoso
Jun 18, 2016 07:32 AM
Munkey
Jun 22, 2003 10:17 PM
