07 5.4 Knock when warm
Old Jan 19, 2011 | 05:03 PM
wreedZ71's Avatar
wreedZ71
I have noticed my truck lately makes a noise likes it knocking more prevelant lower in the engine compartment on both sides. Runs great, oil looks new and its full. It does not sound like a mechnical knock, but something else. Maybe exhaust?
It only does this when its warm and I have been driving it alot. Notice it when shutting it down today in my driveway. I left it running and got out and went inside.<!-- google_ad_section_end --><!-- / message -->
<!-- controls -->
Old Jan 19, 2011 | 07:40 PM
Wilber15's Avatar
Wilber15
Problably cam phazers. They get noisier when they are at full operating temp. Could be a leaking chain tensioner as well.
Old Jan 19, 2011 | 07:42 PM
wreedZ71's Avatar
wreedZ71
So it sounds like it could be normal? How do I check the chain? I looked the whole engine compartment over and i didnt notice anything.
Old Jan 19, 2011 | 07:48 PM
Wilber15's Avatar
Wilber15
You can't get to the chain without removing the valve covers and looking down the front cover to see if the gaskets blew out on the tensioners. Unless your getting a very loud click from the phazers, or it's causing driveability issues, warranty isn't gong to cover them(at least thats what we've been told)....
Old Jan 19, 2011 | 08:02 PM
wreedZ71's Avatar
wreedZ71
ill continue to monitor.
wreedZ71's Avatar
wreedZ71
it just sounds abnormal.
Old Jan 19, 2011 | 08:50 PM
Wilber15's Avatar
Wilber15
I've seen chain guides come loose and slap around inside the front cover, or the tensioner seals blow out and the chain looses tension causing it to slap...
wreedZ71's Avatar
wreedZ71
Should I run a differnet oil? I am running Motorcraft 5w20
Old Jan 19, 2011 | 09:12 PM
Wilber15's Avatar
Wilber15
That oil is what ford recommends...
Old Jan 19, 2011 | 09:21 PM
BOSSMAN302's Avatar
BOSSMAN302
new tsb is to change engine oil to 5w30 to see if a change in noise happens, most likely cam phasers, but could be tensioner gasket blown out.
Old Jan 19, 2011 | 09:22 PM
wreedZ71's Avatar
wreedZ71
Could you PLEASE post a copy! I will change tomorrow.
Old Jan 19, 2011 | 09:45 PM
BOSSMAN302's Avatar
BOSSMAN302
could not find on ford web site but do recall seeing something about it, did find tsb which does apply to your truck tsb 10-18-4 most likely cam phaser. good luck
Old Jan 19, 2011 | 09:52 PM
Wilber15's Avatar
Wilber15
That tsb is for 2009-2010 model years only. I checked for 2007 tsb's, and there is nothing pertaining to cam phazers.
Galendor
Nov 5, 2015 03:01 PM
AJMacleay
May 15, 2015 09:12 PM
Jimmyrig
Sep 5, 2013 01:59 PM
rayjann
Jan 26, 2012 05:42 AM
epos48
Apr 20, 2005 11:14 AM
