Starting problems
Old Jan 19, 2011 | 02:16 PM
Alex3377's Avatar
Alex3377
Starting problems
first off im talking about a 1994 f150 5 speed man. trans 4.9L straight 6. when i went to start it one day it was having trouble stating. it would crank but never turn over. i finally got it started crankin on it, but since then i havent been able to. when i try to start it, i hear the fuel pump kick on, but thats it. its like im not pushing the clutch in. thought it was the clutch safety switch, i bypassed that, its still doing the same thing. i checked starter connections and they are good. i was thinking maybe it could be the solenoid, but i dont have a way to check it. any ideas on what else it could be?
Old Jan 19, 2011 | 02:49 PM
88n94's Avatar
88n94
Very easy to check the solenoid. Run a jumper from the small terminal at the top of the solenoid to the large bolt on the solenoid that is farthest from the battery. It should then crank. Now this is the solenoid about 6 inches from the battery. There is another solenoid on top of the starter. If that checks good, read on.
Have someone hold the ignition switch in the start position, while you check to see if you are getting power through that small wire that hooks onto the solenoid. Use a test light or multi-meter.
Old Jan 19, 2011 | 02:51 PM
taisa899's Avatar
taisa899
got beaten to it
Old Jan 19, 2011 | 02:58 PM
88n94's Avatar
88n94
Originally Posted by taisa899
got beaten to it
No, I don't want to race, I would lose 99% of the time. I'm a slow typer, and an even slower thinker.
Old Jan 19, 2011 | 06:20 PM
Alex3377's Avatar
Alex3377
still a no go...
checked both solenoids. both are working according to the tests. any more ideas??
Old Jan 19, 2011 | 06:33 PM
Duct Tape Racing's Avatar
Duct Tape Racing
ignition switch?
Old Jan 19, 2011 | 06:37 PM
Alex3377's Avatar
Alex3377
no ignition switch is good
Old Jan 19, 2011 | 07:33 PM
88n94's Avatar
88n94
I'm assuming the engine cranked over when you did the test I mentioned in the first paragraph under #2? Did you do the test I mentioned in the second paragraph under #2?
Old Jan 19, 2011 | 08:29 PM
Alex3377's Avatar
Alex3377
yes it did
TyBragg
50
Jan 28, 2014 07:29 AM
puck1263
May 24, 2006 01:08 PM
smeezy
Apr 22, 2005 09:58 AM
