1978 - 1996 Big Bronco
Steering slop
Old Jan 21, 2011 | 09:42 PM
greystreak92's Avatar
greystreak92
Most parts chains will carry them. You might have to order urethane versions but they are available.
Old Feb 4, 2011 | 08:41 PM
Matt In Detroit's Avatar
Matt In Detroit
Just wanted to update this. After thouroughly checking out the steering and suspension, i was able to determine that all the movement in my steering was above the steering box. Meaning there was a good 50 degrees of steering wheel movement with no pitman arm travel. I decided to give the sector shaft adjustment a try. I turned it in about 1/3 of a turn and went for a test drive. Wow.. totally different truck, feels tighter, virtually no wander. Steering returns to center, all is good. I am tempted to go a little more but i think ill leave it. So I am glad i gave it a shot, i realize its kind of a band aid fix and the box probably needs work, but for now, ill take it.
Old Feb 4, 2011 | 09:05 PM
ErrorS's Avatar
ErrorS
I was tempted to give mine a little more, don't do it.. if you're happy in the least bit, leave it.
I now have bind, cant lock my wheel completely (getting better, just have to get it some force near lock) and the play is as bad as it was in the beginning. My pivot arm bushings are also shot, so it might be coincidence that the play is worse. Redhead box and new bushings are only one paycheck away for me.
Old Feb 4, 2011 | 09:12 PM
FourXFord2's Avatar
FourXFord2
My 91 had lots of play when I bought it too. Retorqued the suspension lift bolts, replaced pivot bushings and the radius arm bushings. That alone fixed 1/2 of the problem. Then noticed the shaft from steering column to the box was loose/had play in it when moving wheel. Rplaced with a good used and now it steers great!
Old Feb 17, 2011 | 08:52 PM
USAFCrewChief's Avatar
USAFCrewChief
I'm having the same problem on my 84. Where exactly is the screw that adjusts the sector shaft? sounds like this would solve my problem.
Old Feb 18, 2011 | 06:12 AM
b4hntn's Avatar
b4hntn
It is on the steering box. I would suggest to forget about it because the major wear in the gear is straight ahead. However, if you must, loosen the lock nut, turn the screw 1/8 turn clockwise and hold it while tightening the lock nut. Drive it for several days. This will not repair worn gears.
Old Feb 18, 2011 | 07:30 AM
USAFCrewChief
OOOOHHHHHH i understand now. All it would be doing is compensating for the wear on the gears in the steering box. Thank you.
Old Feb 18, 2011 | 09:24 AM
NASSTY's Avatar
NASSTY
I adjusted the sector shaft on my old steering box a couple months before I bought the Rehead steering box.It seemed to take some of the play out.But after a month my steering box started leaking.
Old Feb 18, 2011 | 10:44 PM
USAFCrewChief
How much do the redhead boxes cost?
Old Feb 19, 2011 | 01:25 AM
NASSTY's Avatar
NASSTY
After getting my core charge back it was about $280 shipped.It only took 2 days to get here, from Seattle WA to Maine.It's not cheap but from what I've heard, I wouldn't have been happy with a cheap remanufactured steering box.
Old Feb 19, 2011 | 07:51 AM
helirich's Avatar
helirich
Do not buy a AGR box. I bought one and it was worse than the box I removed. I called them and they sent me instructions on adjusting the sector shaft. I would have thought it would be adjusted when I got it. The Red Head costs about the same and it is ready to bolt in. I have had to adjust it a couple times in the last few years. But that is probubly due to my big tires. And so far, it adjusts good for the whole range. Not just in the middle.
I must repeat, dont be afraid to adjust the sector shaft. I have done this many times on all sorts of vehicals. You might make it too tight, but you will know it on the first drive. It will not return to center. Back it off and try it again.
pat420swed
Jul 2, 2016 08:44 AM
northernroots
Apr 12, 2016 11:38 PM
djmichael24951
Dec 6, 2015 04:34 PM
Low 150
Jul 11, 2015 12:24 PM
TonyJestis
15
Nov 5, 2012 06:13 PM
