long block
Old Jan 19, 2011 | 01:43 AM
KJLYPW's Avatar
KJLYPW
Unhappy long block
Well, after my christmas no start, and a new IP timed up my truck is running again, and seams to run well, however it now has a very definite clunk clunk ie like a failed rod bearing. Compression test all 400- 420 except hole #7 @ 280! So bent rod, cracked piston?! Rockers, pushrod and valve springs all OK on #7, so I am about to pull the engine.
My question is has anybody bought a rebuilt 7.3 from Hiperformer out of Spokane Wa. Their web site and testimonials all look good and claim only a 1.7% warranty claim. No major engine shop around B.C. here deals with 7.3 IDI's, they have all steered me to auto wreckers - humph.
Will see what I find, but with 282,000km, (175,225miles) I think I would be just as far ahead to get a long block at 3250 USD as try to repair my high milage motor!?
Any thoughts appreaciated.
Old Jan 19, 2011 | 07:12 AM
Scratcher's Avatar
Scratcher
Personally I'd for for a 6.9 which can be bored out. Rebuilt 7.3's are sleeved due to the thinner cylinder walls and I've heard some horror stories on here about sleeved rebuilt 7.3's
Ford Truck Enthusiasts Forums - View Single Post - Good sources for remanufactured 6.9?
Old Jan 19, 2011 | 06:11 PM
KJLYPW's Avatar
KJLYPW
Anybody know about Hiperformer- local business name S&S engines in Spokane.
Or any rebuilders in Sothern B.C. area. Started pulling engine- no coolant or metal in the oil, so I may get luck with a repair.
Old Jan 19, 2011 | 07:10 PM
David85's Avatar
David85
Don't know of any rebuilders that I would recommend to build an IDI. Hardly anyone bothers with them around here. If its not a cummins or a screaming chevy small block no one really knows what you're talking about.
TER holdings here in town is pretty good but I don't know how good they are with diesels like this. I can tell you right now they won't have a long block for exchange in stock but they could help with rebuilding your engine (or do it all at for $$ and time).
They are the shop I went to when I rebuilt my engine. Ordered all the major parts and had the block refreshed there.
Old Jan 20, 2011 | 02:56 AM
KJLYPW's Avatar
KJLYPW
Thanks David, will see what I need once I get it appart. So all the rest of you IDI'er beware- not many business's willing to support these engines anymore, look after what you have!
Old Jan 22, 2011 | 08:37 PM
KJLYPW's Avatar
KJLYPW
Found my #7 connecting rod bent- may have been a stroke of luck, as I will now proceed with a rebuilt once I get things measured up. Turns out all of the connecting rod bearings are showing wear, some of them starting to show copper, so a rebuild before any other abnormal wear the crankshaft or other bits. Also a bit of luck, this block is a "Turbo IDI" 1809000C3 casting - is suppose to be a stronger block, and has the bigger piston pins- so definatly worth rebuilding. Hardly any noticeable wear in the cyclinders, and water jackets look very clean- hopefull no cavitation worries. Does anyone know if the C3 blocks had thicker cylinder walls??
Old Jan 22, 2011 | 09:15 PM
Scratcher's Avatar
Scratcher
Whats the mileage on that motor?
Old Jan 23, 2011 | 12:38 AM
KJLYPW's Avatar
KJLYPW
175K miles
Old Jan 23, 2011 | 11:50 AM
PLC7.3's Avatar
PLC7.3
Your not even close to 1/3 life of that block......usually 500K miles minimum.
SCA's are very important though........
The guys at the shop got a Ford crate engine for $5000 a year or 2 ago through Ford in Canada.
Old Jan 23, 2011 | 01:52 PM
Aune163rd's Avatar
Aune163rd
Originally Posted by KJLYPW
175K miles
These Engines are fine up to 500k-700k if you take care of them. My 6.9 is from 1986 and has 575,824 miles on it. Still runs but has a blown head-gasket. Just replace your bearing set and your connecting rod that is bent. If all your other parts on the engine are fine i would replace whats needed, put her back together and throw her back in the truck. Make sure you use SCA's. They will stop cavitation, you should be testing your engine regularly.
Old Jan 23, 2011 | 06:42 PM
KJLYPW's Avatar
KJLYPW
I've always added the Ford SCA additive since I've owned the truck- 6 years, from what I can see of inside the water jacket its as clean as can be (looks like a greenish glazing)-as was the coolant. So I dont really think there are any issuse re cavitation, but will pressure check just to be safe.
Old Jan 23, 2011 | 08:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There was a place I talked to out there Diesel Auto Services was the name if I remember right.
Somewhere in BC not far from the border, again if I remember right.
I can't find the link right now.
Old Jan 23, 2011 | 08:39 PM
KJLYPW's Avatar
KJLYPW
Thanks Dave, already talked to them, don't do rebuilds anymore- sent me in the direction of the wreckers. Anyway, looks like a overhaul kit in my near future, any body bought the kits on e-bay from Grumpys Performace in Oregon?
Old Jan 23, 2011 | 09:26 PM
Dave Sponaugle
Thats a shame, the guy I talked to seemed to have a good knowledge of the IDI engine.
But that has been probably 4 years or more ago.
harleymsn
Mar 10, 2015 10:30 PM
Fast_4x4
22
Nov 5, 2014 02:27 AM
mgerdau
Sep 11, 2014 11:19 AM
Romanova
Aug 7, 2014 05:45 PM
Icicle
May 7, 2014 10:07 AM
