2 wheel frame
Old Apr 4, 2004 | 09:31 AM
cannonfodder's Avatar
cannonfodder
2 wheel frame
Will my 79 F 250 4x4 front housing and springs bolt on to a 79 2 wheel drive 1 ton frame.
Old Apr 4, 2004 | 07:51 PM
doc_f250's Avatar
doc_f250
No...
Doc
Old Apr 4, 2004 | 11:41 PM
oldhalftons's Avatar
oldhalftons
nope, nada, no way.
Old Apr 5, 2004 | 05:23 AM
cannonfodder
A little more info please
Why not? Too wide to narrow? I may have to break out the torch and welder? Thanx
Old Apr 5, 2004 | 05:34 AM
Dave76's Avatar
Dave76
2 wheel drive frame is narrower. What all are you trying to swap over?
Old Apr 5, 2004 | 05:44 AM
cannonfodder
Rusty F250 frame
I have a rotten F250 4x4 high pinion 44 , 460 c6 205 and dana 60 and there are lots of 1 ton 2 wheel frames I thought I would put it all under a 1 ton frame . They appear to be stronger and the rust is bad here. Plus I have been known to load heavy. I will put this together Just wondered how painful it was gonna be. It's still in the snowbank yet. I was hoping someone had been as adventuresome or foolish as to try this.
Old Apr 5, 2004 | 02:44 PM
78Extended's Avatar
78Extended
pre 76 2wd frame to 4x4 convertion
i just converted my 73 2wd crew cab f350 to 4x4. the front spring perches came from a pre 77 1/2 highboy and they just bolt right on all the holes are already in the 2wd frame for those. the front spring shackle brackets came off the same truck and while the holes werent there i just layed it out and drilled knew holes and bolted them on. works perfect.
Old Apr 5, 2004 | 03:20 PM
cannonfodder
We're gettin there
Thanks 78extended. That's what I wanted to hear. I think I read that the hiboys had a narrower frame. Is this from front to back fellas or only on the rear? More info is good Thanks in advance. I'm sure someone here has this all figgered out
Old Apr 5, 2004 | 07:20 PM
cannonfodder
Don't be shy boys. Let's hear it . If you think I'm nuts for doing this please say so. I will post pics of the process. I was just hoping someone else had done it first. I have no desire to be the first. Just want that rugged frame under my truck. If the original was any good I would clean it up and blow some Tremclad on it
79-ford-f150
Mar 28, 2014 03:53 PM
66f250
Jul 1, 2013 07:43 PM
66f250
Jul 1, 2013 05:31 PM
bluesclu978
Feb 13, 2011 07:52 AM
79 Big Block Ford
Mar 24, 2002 03:56 AM
