need help ford c6 problems
Old Jan 18, 2011 | 09:33 PM
reavis's Avatar
reavis
i have a 79 ford 4x4 460 with a c6 transmission transmission was slipping in 2nd and drive so i pulled it out put a rebuild kit in it when u first take off it works great. heres the problem after running a little while and u take it out of drive and back up or even put it in park when u go back to drive there is nothin doesnt pull at all in any forward gear have rebuilt several of these transmissions and never had a problem any ideas
what could be wrong
Old Jan 18, 2011 | 11:33 PM
mark a.'s Avatar
mark a.
Did you do a air check before you put the valve body back in ? Did you flush the lines and cooler out before you put it back in ?
Old Jan 19, 2011 | 10:56 AM
reavis's Avatar
reavis
yes i air test before valve body and cleaned out lines and put a new cooler on it did away with factory radiator one
