Also if its a 4x4, a srw will most likely have 3.73 gears, most drw trucks have 4.10 from factory, although a few had 3.73. If it is an 02 srw it will have the 10.5 sterling and not the 10.25, drw will be the d80.
Its srw so that makes it a 10.5 Sterling?
Im looking at buying parts off Ebay is why Im asking.
If you are looking at buying a ring and pinion, order the ones for the 10.25 sterling and an install kit for a 10.25, they will drop right in no problem and the 10.25 parts are cheaper than the 10.5 parts.
