I bought a f660 and was wondering if anyone "number dummy" hint hint could help me out figuring out what all it is.
It is a 4x4 5 speed and a 331 i beleive, it is an old line truck that i think will do well with trimming trees and such. Where else would i look to find the trans, and axle id and ratings.
F66EVAG12xx
Welcome to FTE
No such thing as an F660, it's an F600. F66 is the VIN's Series code only.
The Model code (listed on the Warranty Plate) will prolly be either F650, F660 or F661. All three are F600 4WD's with a specific GVW for each code.
F66 = F600 4WD (gas).
E = 361 2V FT Engine.
V = Kentucky Truck Assembly Plant.
AG12XX = 1978.
Look on the Warranty Plate (located on the left door face below the latch) for the VIN, codes for the W.B., Color, Model, Body, Trans, Axle, Year (will be specified), GVW, DSO.
climb under and look at the tags on the tranny and transfer case , the older ones had Clark 5spds , my 1974 has a Clark 5spd ! axles should be Rockwells f106 !
