Thanks for going to all the trouble! That is the same gear I have in mine. But with 235/75/15's my speedo was off buy quite a bit. That was the most teeth I found for that style gear. I just put on 31/1050's and I am within a couple of miles of being accurate now.
I just jumped from 215R75x15's to 30x9.5x15's. Have only driven it about 10 miles, but would guess that I'm doing almost 65 when it says 60, which is consistent with what the math says - 64 when reading 60.
Any rodders out there? I need to swap my manual 3 in-the-tree manual trans bolted to a Y-block V-8 for an AOD automatic on my 57 F-100 SWB. Don't I need to switch bell-housings? Any other suggestions, please.
