Will it start without trans ?
Old Jan 17, 2011 | 09:51 PM
JRS2's Avatar
JRS2
Working on putting at 4 wd with a 5 spd back in the F150. There are sensors, likely making it not possible to start without any plugins for the transfer case (which is manual) and the 5 speed. Anyways, if I attempt to start it, what's your guess - will it start or not ? If not, what can I do to get around it ?
Thanks, want to see if getting any oil leaks while engine running ....
Old Jan 17, 2011 | 10:00 PM
Conanski's Avatar
Conanski
There are no sensors of any significance on a manual transfer case and transmission so yes the motor will start and run normally... assuming the truck originally had these same components in it and is still using the same wiring harness and computer.
Old Jan 17, 2011 | 10:36 PM
F150xlt's Avatar
F150xlt
The title of your post is "Will it start without trans ?'"
The starter bolts to the transmission bell housing. So if you don't
install the transmssion, you can't crank the engine.
Old Jan 17, 2011 | 11:59 PM
xxshine's Avatar
xxshine
When i did one of many conversions from A/T to manual, i found the necessary wires from the A/T, and crossed them up. Same with those stupid clutch pedal wires where the motor won't turn over til the clutch is pushed to the floor.
Old Jan 18, 2011 | 08:25 AM
pro70golfer14's Avatar
pro70golfer14
But like previously stated you cant bolt the starter to nothing unless you got the transmission in. Chevy bolts to the block so you could do it with one of those pieces of junk.
But in your question we will assume you are talking about a ford truck, so no.
BRay09's Avatar
BRay09
Unless you are like the hulk and can spin the motor by the flywheel fast enough to get it to start
Old Jan 19, 2011 | 06:45 AM
pro70golfer14
True. I stand corrected.lol
Old Jan 19, 2011 | 02:43 PM
JRS2's Avatar
JRS2
Ok, thanks guys ...
Old Jan 19, 2011 | 02:49 PM
danger-ranger93's Avatar
danger-ranger93
Now guys hold on, my old RTS that I had in my 87 you could take the bellhousing off the tranny and put it on the block and be able to start it, so technically it can be done. But he said he had the 5 speed so unless he's (or she) using black magic he can't start it without the tranny.
Old Jan 19, 2011 | 05:00 PM
lew52's Avatar
lew52
Just wrap a rope around the flywheel , and pull start it...Lew
Old Jan 19, 2011 | 06:40 PM
BRay09's Avatar
BRay09
I forgot for a moment that the bellhousings came off of the older trrans... so in theory you can start a motor with the trans off if you have a bell housing from an older truck you could but on there temporarly to start it.
Or do as lew said and pull start it
wildbill3336
Jan 5, 2013 12:02 AM
firefighterwilbanks
17
Nov 27, 2012 06:44 AM
vernon_25
27
Jun 15, 2010 11:15 PM
mx boy
1983 - 2012 Ranger & B-Series
Jun 2, 2010 06:42 AM
muscletruck7379
Sep 16, 2003 02:06 AM
