Sponsored by: Real Truck
Alternator Reading 13.4
Old Jan 17, 2011 | 06:09 PM
StangPullerF250's Avatar
StangPullerF250
I got stranded last week and bought a new battery. It has started every morning for a week, but just to be sure I took it to AutoZone to get the alternator tested. The guy hooked up his computer and it read 13.4 and told me that it needed be replaced ASAP. I was reading a couple places online and they all said if it reads under 13 that its going bad/is bad. Mainly I just want to know if I can get around safely for a week of two. Any input would be appreciated. Thanks guys.
Old Jan 17, 2011 | 06:17 PM
gearloose1's Avatar
gearloose1
Specifics please.
Gas or diesel?
One or two battery? Did you just replace one of two?
OEM Ford alternator?
Do you run additional (non stock) electrical loads like seat warmers, ghetto blasters, plows, emergency lights, winches, etc?
Cables? Stock?
Old Jan 17, 2011 | 06:29 PM
StangPullerF250
Original alternator
no extras
bone stock
Thanks GearLoose
Old Jan 17, 2011 | 06:38 PM
gearloose1's Avatar
gearloose1
Double check Ford specs for the alternator voltage.
But to me, that is pretty normal voltage.
If you have AC on, etc. it would pull it down even more.
The definitive test --- hook up a voltmeter to, eg the cigarette lighter.
Fully charge battery overnight.
Verify battery cables / alternator cables have no problem etc.
Take it for a long drive (over 5 or 10 miles, so it has time to charge battery up the power used in starting).
Then, measure the voltage with engine rpm constant (above 2,000) with no headlights, etc. on.
If you are over 13.5 volt range, you are probably OK for quite a while.
If you are over high 13s or around 14.
There is nothing wrong.
A Voltage test by itself tell you not much --- you need simultaneous measure of voltage and current (to get power output).
As you can see, I think the fella that sold you the line is trying to sell you something you probably don't need.
Oh.. now for my advert.
Replace it only with a Ford reman / new with exactly the same part number.
You will find the part will outlast the average Autozone alternator by far.
Even if it comes with a lifetime warranty, you still have the hassle of putting it in --- and having a failure on the side of the road.
Old Jan 17, 2011 | 06:49 PM
StangPullerF250
Do you think I would be good for driving a half - hour commute tomorrow until I can check it out this weekend. Thanks again for your help, it was very helpful.
Old Jan 17, 2011 | 07:18 PM
gearloose1's Avatar
gearloose1
Charge the battery full tonite.
The reserve capacity (you should know or can look it up) for your new battery is published.
Bet you that can power you for 30 min or so with the alternator completely dead, if you turned everything non-essential off (headlights, radio, etc.)
I would hook up a volt meter and monitor voltage carefully for a week, but I would not hesitate to think there is nothing wrong and delay replacing the alternator indefinitely unless I see other symptoms of failure.
Old Jan 17, 2011 | 07:40 PM
StangPullerF250
I just checked and the reserve capacity is 150 mins. I am going to charge it overnight. I drove it a half hour home when I replaced it, started it several times in the drive way, and drove it around 5 miles to autozone and back. The lights aren't dimming or anything, I think it's fine.
Old Jan 17, 2011 | 07:48 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Did you actually pull the alternator and have them bench-test it, or did you simply have them do the 'whole system' test in the parking lot? The 'whole system' test doesn't take into account the draw of charging after starting, any lights that might be on (such as your interior lights from the door being open, etc) or the fact that your fuel pump might also be running. A bench test actually tells you what the alternator is putting out (both volts and amps), and tests what it does under a full draw. I always recommend a bench test before deciding if you need to replace an alternator.
BTW, most Autozone employees are going to try to get you to replace something whether it needs to be or not. I also had one try to tell me O2 sensors don't tell you how your catalytic converter is operating. THAT was a classic conversation.
LiftedBlackHD
May 15, 2014 06:00 AM
Randy777
Sep 17, 2013 12:13 AM
ROBBINthaHOOD
Jun 13, 2013 05:35 AM
billtrev
Jul 7, 2010 06:29 AM
laka
May 11, 2008 09:52 PM
