Rough idle, FICM, ICP, VOLTS or other???
Truck is becoming hard to start and idles rough. While idling the cab bounces up and down mildly.
I did some tests today and the findings are as follows:
At idle I am getting 13.8-13.9 volts at the batteries and 13.9 volts at the alternator measured with the voltmeter, with NO acessories on. These numbers drop to 13.2-13.3 and 13.4 respectively with all acessories on.
According to my SCT at idle with everything on I am getting 13.0. With acessories off it jumps to 13.7.
I tested the FICM and I am getting about 47.5 with key on and at idle.
I then pulled the ICP sensor and there is no noticeable change in sound or RPM at idle. Plug it back in and again no change. I tried this several times with negative results. The ICP was replaced a few years ago. When it went bad the first time the idle was jumping up and down and the truck would die. It is not currently experiencing those symptoms. Just a steady rough idle.
Any opinions?
Thank You
Any opinions?
Thank You
Any opinions?
Thank You
Any opinions?
Thank You
Oh and no DTC's according to SCT.
thanks
I recently had voltage issues. Was seeing p1378 FICM supply voltage low. Was having rough starts, rough initial idle. Found that my driver side battery terminal had cracked. Actually it was split in two. A film of corrosion had built up and the alternator was unablevto properly charge the battery. Over a period of time the battery deteriorated to the point of hard starts/rough idle.
Check your lugs for damage, not only battery post contact but at the crimped end of the lugs, negative and positive. Maybe you have already done so. If you havent , it would be easy to do so. Load check the batteries next, individually, to ensure they are at their proper strength /CCA. Check ground straps for damage and good electrical connection. Hope you find the problem!
I needed to replace my positive cable. The whole shabang.
Eric
Eric
your only seeing one side of the FICM that's Main, you need to see VP and LP the solder joints break, also double check the 3 connections and pins they bend real easy. Benny had Mentioned ICPV ( volts ) the Pig tail will give some weird results stalling , bucking , high rpms, and wack volt values. you should get at least a Scan Gauge and enter the X gauges
Fordenthusiasts
05-10-2016 10:28 PM
tennesseecoalroller0
30
03-19-2012 08:32 PM
