Hydroboost ??
Old Jan 16, 2011 | 08:26 PM
grinnergetter's Avatar
grinnergetter
Hydroboost ??
#1 Can I run it upside down?
#2 Want to upgrade PS pump and from my research you folks seem to like the saginaw. Fine. Any particular vehicles that traditionally run this pump.
(so i dont have to lift every hood in the JY) This is going on a 460.
Thanks, Grin
Old Jan 17, 2011 | 10:04 PM
grinnergetter
Anyone? At least the upside down question?
Old Jan 17, 2011 | 11:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Run the boost unit upside down? I suppose you could, but there is no reason too.
Josh
Old Jan 18, 2011 | 04:48 AM
ford390gashog's Avatar
ford390gashog
Yes the booster will work upside down, but why??? Seems like you are trying to reinvent the wheel on this one.
Old Jan 18, 2011 | 07:21 AM
grinnergetter
Upside down will allow the unit to fit right with only slightly elongating the bottom mounting holes. Also there would be lots more room to remove valve cover. I'll have another look at it today.
I spoke with Hydratech yesterday and they said you could do it but some applications had to be reclocked. Their unit sells for $890.00 No PS pump.
Holy toledo.
Old Jan 26, 2011 | 08:31 AM
grinnergetter
So I got back to the brakes and removed the mounting plate so I could flip it around. Duh. Knocked out the studs and put 2 bolts in to hold it in place.
My rod coming out of the hydro is about an inch too short with the unit bolted directly to the firewall. So, did I get the wrong one or do I weld a ext on the brake pedal lever?
From my research it seems that most of you had to shorten the rod. My parts guy said it fit many models from the late 90's.
mitchgordon96
Dec 2, 2014 01:10 PM
jdiam00
Jun 9, 2013 03:30 PM
kynnhoj
Aug 11, 2012 10:26 AM
BluePitt
34
Jan 9, 2012 06:52 PM
mauicruza
1966 - 1977 Early Broncos
13
Feb 10, 2005 05:37 AM
