Rusty Lug Nuts-How To Remove?
Old Jan 16, 2011 | 05:43 PM
Roger T. Pipe's Avatar
Roger T. Pipe
I just picked up a rusty but running '94 350 plow truck. The lugs are rusted beyond belief. It looks as if the wheels were never even removed from this truck! Well, I'm the type that likes to be prepared so what can I do to loosen/break these lugs? I soaked them with PB Blaster but honestly I think they're too rusty for that. Would applying heat help? Plumbers torch? Any ideas would certainly be appreciated!
Roger
Old Jan 16, 2011 | 05:53 PM
Volvo92906's Avatar
Volvo92906
Id try the heat and if worse comes to worse, torch em off. I can cut a nut off without damaging threads so its possible. Ive had to do it before for the same problem youre having. Thats all I got. Good luck.
Old Jan 16, 2011 | 05:55 PM
Turx's Avatar
Turx
I'd keep soaking them down with the PB, for a few days. Heat won't hurt and actually draws the PB in. Heat the lugs up, not cherry red, and spray them down. If that doesn't work get them good and hot, red, and they'll come off. I just went through this myself on an old plow truck. Be ready for a lot more, lines, brackets and brake parts if the lugs are that bad. Been there...
Old Jan 16, 2011 | 06:57 PM
Roger T. Pipe
OK, I'll try the heat first/PB Blaster trick....I have time since I don't need to change rims or tires yet <fingers crossed> but come Springtime I'd like to put a decent set of tires on this truck. The current ones are terribly dry-rotted~
Roger
Old Jan 16, 2011 | 07:24 PM
Newcomer's Avatar
Newcomer
x3 on the heat, I bet you wont have to cut them off, if you get them hot enough, ecspecially if you can get them glowing red and then hit them with an impact they should spin off..
Old Jan 17, 2011 | 12:04 AM
capn kirk's Avatar
capn kirk
pb, heat, and try alternating between hitting it with an impact wrench (let the wrench work it you're going to have to hold it on for a bit) and a breaker bar.
if they just wont go follow the rule- when in doubt cut it out
Old Jan 17, 2011 | 02:26 AM
Sonksen's Avatar
Sonksen
Heat, definately heat. Any oil based lube will need to be completely cleaned off of the studs before mounting... we have had lug nuts work loose on HMMWVs in theatre resulting in studs breaking and wheels falling off while on mission. There was an investigation each time this happened. Out of the five times that happened, four were due to lug nuts being over-tightened (stretching and weakening the studs), and one was due to the operator using WD40 when removing his lug nuts. He had been doing that all year, but that one time, there was just enough trace amount of WD40 on the studs to cause the lug nuts to work loose! I had never heard of that before but since seeing that paperwork with lab results I haven't used anything on studs except anti-seize (hopefully anti-seize won't cause the same thing, I use it for bud nuts on freightliner duals)
Sorry for rambling, but I would use the torch and heat them up, or possibly just cut them off and replace.
Greg Rogers
WTB - Parts & other
Aug 21, 2016 07:45 AM
Roger T. Pipe
Aug 9, 2016 09:20 PM
Rusty_S
May 28, 2016 04:46 PM
49 ford fire truck
Ford Truck Parts for Sale
Jul 13, 2015 10:40 AM
Roger T. Pipe
Apr 22, 2015 06:00 PM
