300 i-6 header
Old Mar 14, 2003 | 01:58 PM
ROTCJS's Avatar
ROTCJS
300 i-6 header
sounds pretty sweet. when ya gettin home from japan?
Old Mar 14, 2003 | 11:04 PM
Pkupman82's Avatar
Pkupman82
300 i-6 header
Yeah she looks pretty clean for a 19 year old. I will probably be taking leave sometime in June or July of 2004. But I leave Japan in January 2004. When I get home I plan to install a 2 inch suspension lift on her so I can run 33s. I eventually want to have her professionally repainted. I could go on for days about the rest of the things I want to add. An old truck is never done!
Old Mar 14, 2003 | 11:23 PM
ROTCJS's Avatar
ROTCJS
300 i-6 header
your right! i plan on going up to spend a month or se with my dad in june or july, should take your truck around wolf lake this summer i might see ya!
Old Mar 15, 2003 | 12:03 AM
Pkupman82's Avatar
Pkupman82
300 i-6 header
More than likely I will be down there fishing with my buddies, you'll probably see my truck parked at the boat launch. And not only that but my Dad has a friend who lives on Wolf Lake too. You can't miss it, It sticks out like a sore thumb with all those lights on top! I never have to worry about losing it in big parking lots! HaHa! Will you have your truck up there by any chance?
Old Mar 15, 2003 | 07:49 AM
broncr's Avatar
broncr
Thumbs up 300 i-6 header
I'm in the same boat with my '82 Bronco. I looked for a long time before finding a set of Hooker super comps in Jegs for around $300. The collector flanges (sold in twos) are another $20. Clifford performance has a set for under $300 but I've had no success getting them to respond to e-mail (it's ONLY been a week - maybe I should try snail-mail!) They do have some great pictures of them there (Cliffordperformance.com)
Old Mar 15, 2003 | 09:54 AM
ROTCJS's Avatar
ROTCJS
300 i-6 header
yeah i'll have a truck up there, but it won't be getting driven around. since this is my summer before college, me and him are gonna fix up a truck that ibring up there, haven't decided yet if it will be one i have now or maybe something older. but you might see us cruising around with him on a big loud harley and me on a kawasaki ninja, or in the mustang he is restoring.
Old Mar 16, 2003 | 03:12 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
300 i-6 header
thanks broncr for getting back at the subject at hand. I hope this helps ford tractor 33 with his problems.
Old Mar 17, 2003 | 06:04 AM
Pkupman82's Avatar
Pkupman82
300 i-6 header
Yes they do if I remember right I think they were going for about 280 bucks. EFI manifolds?
Old Mar 17, 2003 | 07:01 PM
Silver Streak's Avatar
Silver Streak
300 i-6 header
The Hedman headers are $135 from Summit. Here's the link.
http://store.summitracing.com/partdetail.asp?part=7075
They say 2wd drive only, but comparing a 2wd and 4wd drive truck side by side I can see no reason why they don't fit the 4wd. Maybe someone out there knows.....
FWIW, I don't think there's much price difference between changing to headers or EFI manifolds. I went from the EFI manifolds to headers and have never regretted it a bit. Well, maybe a little bit when my starter went out. Around here the EFi manifolds are going for $100/pair at the boneyard and it costs $20-30 more to have exhaust built to meet the manifolds. My headers came with the collector adaptors.
Old Mar 17, 2003 | 09:05 PM
whittey's Avatar
whittey
300 i-6 header
My Hooker Supercomps are for either 2wd or 4wd, and if they were a couple inches longer, it would hit the tranny crossmember. My truck is 4wd but i'm not sure if the 2wd crossmember is different.
-=Whittey=-
Old Mar 17, 2003 | 09:58 PM
broncr's Avatar
broncr
Question 300 i-6 header
Jegs has the super comps for $320. (plus ?$ for the flange). The spec sheet says they have a 2-1/2" collector - do yours?. That would be sweet 'cause I already have 2-1/2" exhaust from there back. Where would I go for the coating you recommended? I'm just about convinced that the Hookers would be the easiest/ best move.
Clifford finally replied, "You can run 53-0016 with fittings but our best header is the 53-0960 without fittings" (that was the complete response). I'll have to go to their site and try to sort out what this means...and how much they cost (initially, I found a price of $279). There are NO specs - which is what I had requested, and no weber carb info. at all.
Old Mar 17, 2003 | 10:18 PM
82F100SWB's Avatar
82F100SWB
300 i-6 header
Go with Hedmans, they're cheap, well built(flange is the same thickness as the stock flange) and, they fit both 2wd and 4wd for 80-86... I ran my 82 both ways....
Evan
Old Mar 17, 2003 | 11:20 PM
  #28
broncr's Avatar
broncr
300 i-6 header
where can you find the headmans & how much $? i was on the Clifford site - the 53-0960 is a "dual, 33" 16 gage with 2-1/4" collector" for $279.
Old Mar 18, 2003 | 07:20 AM
  #29
whittey's Avatar
whittey
300 i-6 header
The Hooker is a 1-5/8 primary, 30-something (32 inch maybe?) long with dual 2.5" slip-fit collectors. Clearly thats far too big to be running on a street motor so i'll be necking it down to a pair of 2-1/4 inch then down to a pair of 2" a bit farther down the system. 2x2" is equivalent to a 2-7/8" pipe. The Heddmans are cheaper so i'd go with them if I were you. I got mine used so it wasn't too difficult of a decision. (wanna see something crazy? racesearch.com used to list 'em for like $550 uncoated and like $800 coated, hahahahah)
-=Whittey=-
ibleedblueoval
1997 - 2003 F150
Jan 6, 2013 05:12 PM
Ferrariferg
May 13, 2012 12:06 AM
Spydycarnge
Exhaust Systems
Jan 24, 2010 01:19 AM
05turbo
Jun 1, 2008 04:57 PM
big_beast302
1978 - 1996 Big Bronco
Jan 16, 2003 08:46 PM
