RF Tire Bounce
Old Jan 16, 2011 | 03:57 PM
k_conner's Avatar
k_conner
RF Tire Bounce
So I have read the other posts about the death wobble. Mine is on the right front tire only. Not always but every once in awhile it will really start bouncing. It also pulls to the right while driving. A couple things I have noticed is: when I stand in front of the truck and look at it it looks like the whole truck is tilted toward that right front tire a little. And the last time I changed the tie rod I noticed that the hole the tie rod end bolts through was a little bigger than the one on the drivers side. Tires wear fine though. What do you think? Bushings?
Old Jan 16, 2011 | 04:44 PM
planehunter's Avatar
planehunter
Ball joints, shocks.
Old Jan 16, 2011 | 05:08 PM
RRranch's Avatar
RRranch
If it's squatting on one side then springs probably. Bushings or most likely shackle bushings. YOu need to pull the shackle down out of the frame to see it.
New shocks would help a lot too!
Old Jan 16, 2011 | 06:30 PM
k_conner's Avatar
k_conner
I have never replaced the shocks on this truck. what would you suggest I go with? Brand and type? I dont do a lot of pulling but do hook up the 5th wheel every once in awhile. i have helper springs on the rear. thanks
Old Jan 17, 2011 | 07:29 AM
RRranch's Avatar
RRranch
Ive got rancho 5000's. I would have bought 9000's if my wife had let me. She's paying for it now with black eyes every time I hit a washboard patch of pavement. They definitely keep the tires on the ground.
Don't forget to pull those front shackles down and look at the bushings. I'll bet they are trashed.
Old Jan 17, 2011 | 08:51 AM
k_conner's Avatar
k_conner
Don't forget to pull those front shackles down and look at the bushings. I'll bet they are trashed.[/quote]
RRanch, I am not sure exactly what the shackles are. Are they part of the Shock mounting system? Thanks again....
jmtbiggin
Large Truck
Nov 7, 2021 07:30 AM
bedwar4
2004 - 2008 F150
Aug 19, 2018 08:26 AM
dudewitharanger
1983 - 2012 Ranger & B-Series
Oct 14, 2016 05:11 PM
jackslater
May 4, 2006 11:37 PM
Bentruby87
May 1, 2004 07:57 AM
