Sponsored by: Kumho
front suspension problems
Old Apr 30, 2004 | 03:08 PM
Bentruby87's Avatar
Bentruby87
Angry front suspension problems
Ive got a 94 F150 XLT 4x2 5.0. The front right suspension is doing some odd things. i dont know that much about suspensions, but i know enough to know somethings wrong. Everytime i am turning and hit a bump the entire truck shakes and it feels like the rear tires are bouncing. I jacked it up today, and no matter how high i cranked it, the front right tire would not come off the ground. i know thats not good. maybe a bent tie rod or bad springs or something. Please help!!!
Old Apr 30, 2004 | 07:40 PM
95soontobelifted's Avatar
95soontobelifted
sounds pretty bad, Is your coil spring still in tact? how about the brackets holding it from the top and bottom?
Old Apr 30, 2004 | 09:19 PM
Bentruby87's Avatar
Bentruby87
the tie rod seems to have some play to it also. Spring looks intact, the brackets look ok, the only thing is the spring streches so far down to let the tire stay down. I have no clue how all this happened. i hit curb about a month ago and thats the only thing i can think of. low speed tire side wall contact.
Old May 1, 2004 | 12:19 AM
FSC's Avatar
FSC
Do you have a broken or missing shock absorber?, the axle should only drop to the limit of shock travel.
Old May 1, 2004 | 07:42 AM
Bentruby87's Avatar
Bentruby87
im open to anything, again i dont know much about suspension. ill have to check the other side to see if the shock is missing. unless i didnt see it, there is not one on there.
Old May 1, 2004 | 07:57 AM
Bentruby87's Avatar
Bentruby87
OK, went out and checked the shock. Yes, there is one there(go ahead, call me a newbie!). they are the origianal ones as far as i know, so they should be up for replacement. how do i tell if they are bad, and how do i replace them myself?
