Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Tie rod ends
Old Nov 24, 2016 | 09:02 PM
jmtbiggin's Avatar
jmtbiggin
Tie rod ends
Well I got good brakes on the 1960 F600. Put some good military NDT 9.00-200 on the back and some new Power king 8.25-20 on the front. All lock ring now, no more rh-5° for me. The truck rides and handles great, but while mounting the front driver tire I noticed the tie rod.end is ready for retirement. Gonna do both end while I am under there. Google stinks for finding a part number. Any of you have a clue for the tie rod ends?
Old Nov 25, 2016 | 11:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4,700 lbs. capacity front axle uses different tie rod ends than 6,000 lbs. capacity front axle.
Post the AXLE code stamped on the Rating Plate.
Old Nov 25, 2016 | 01:27 PM
jmtbiggin's Avatar
jmtbiggin
Old Nov 26, 2016 | 09:35 AM
NumberDummy
Thru 1969, if the AXLE code has only 2 digits, the truck has the standard equipment front axle.
1957/60 F600 came standard equipment with the 4,700 lbs. capacity front axle.
C1TZ-3A130-A (replaced C0TZ-3A130-A) .. Right Tie Rod End / Obsolete
MANDERBACH FORD in Temple PA has 1 = 610-929-3683.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 14 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
C1TZ-3A131-A (replaced C0TZ-3A131-A) .. Left Tie Rod End / Obsolete
MANDERBACH FORD has 1.
NOS PARTS LTD has 2.
CARPENTER NOS OBSOLETE PARTS has 9.
Old Nov 26, 2016 | 03:03 PM
jmtbiggin's Avatar
jmtbiggin
Thank you one again.....
Old Nov 26, 2016 | 07:10 PM
jmtbiggin's Avatar
jmtbiggin
I inquired at napa... He sold me #269-2023 & #269-2022.He did inquire which axle I had then said never mind because the both take the same tie rod ends.
Old Nov 27, 2016 | 09:29 AM
NumberDummy
Uh huh...
If it didn't make a difference, I wouldn't have asked.
1957/60 F600 with optional 6,000 lbs. capacity front axle:
B3TZ-3A130-A Right & B3TZ-3A131-A Left .. Tie Rod Ends / Obsolete
Old Sep 7, 2017 | 02:13 AM
PT3's Avatar
PT3
Thank you for the great information in this post. Could I use B3TZ-3A130-A Right & B3TZ-3A131-A Left for my 1969 F600? Below is my rating plate.
Old Sep 7, 2017 | 02:51 PM
NumberDummy
No.
3rd digit of the AXLE code refers to the front axle. B = 5,500 lbs. capacity.
1967/72 F500/750 with 5,500 lbs. capacity front axle:
C7TZ-3A130-D .. Right Tie Rod End / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 9 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 34 = 800-543-4959.
C7TZ-3A131-D .. Left Tie Rod End / Obsolete
GREEN SALES CO. has 7.
CARPENTER NOS OBSOLETE PARTS has 15.
Old Sep 10, 2017 | 01:27 PM
PT3's Avatar
PT3
Ford F600
Thank you for your help! It is greatly appreciated!
Old Nov 6, 2021 | 05:51 PM
ev1's Avatar
ev1
Hi Bill,
You have helped us with part numbers before, thank you, and we are in the weeds again.
If I understand this old post of yours, our truck, a '61 F600 with "64" as the axle code, would be the std. equip. axle of 4,700lbs and use these two PNs.
Just confirming that i understand that correctly before i try and find them?
Thank you, steve
Old Nov 6, 2021 | 07:45 PM
85e150's Avatar
85e150
You may be waiting a long time.
As I understand it, based on the notes in the Master Parts Catalog, the two digit axle code--in other words, no code for the front axle--means the standard axle, which is as you say for your truck, 4700 lbs.
Old Nov 6, 2021 | 08:38 PM
ev1's Avatar
ev1
thank you for replying. much appreciated.
i do not understand the 'waiting a long time' note?
if i have the 4,700lbs axle, then the C1TZ ... should be the ticket ... if i understand correctly.
sorry for the double checking. PNs are not my thing ...
thanks,
steve
Old Nov 6, 2021 | 08:48 PM
85e150's Avatar
85e150
What I mean by that is Numberdummy does not visit here as much as he used to.
I think you have it, now to see if you can find those parts. Good luck!
Old Nov 7, 2021 | 07:30 AM
ev1's Avatar
ev1
Thanks a bunch for your replys, very much appreciated.
I'll post how it works out.
ev1
uglybus
Oct 25, 2018 09:31 PM
LosOsos
May 27, 2016 07:35 PM
raytasch
WTB - Parts & other
Dec 25, 2012 11:33 AM
vegas
21
Apr 4, 2005 12:08 AM
