ATF in engine
Old Jan 16, 2011 | 09:17 AM
XBAJBUSX's Avatar
XBAJBUSX
ATF in engine
My truck has about 300k on it I'm changing my oil in less then 100 miles from now and I'm qt low I was reading some place if you add ATF in you engine it will clean the engine from all the gunk .should I due it is it safe ??? Please let me know or what should I use .I run shell oil in it since day one
Old Jan 16, 2011 | 09:20 AM
Muktown's Avatar
Muktown
Never run anything but oil in the oil tank. You can put atf in the fuel tank and fill the bowl with it to help clean some junk out of the fuel system.
Old Jan 16, 2011 | 10:21 AM
JamesHajek's Avatar
JamesHajek
No. Just run your oil. Don't put additives in it. You can burn ATF as a fuel.
Old Jan 16, 2011 | 11:55 AM
richdawg's Avatar
richdawg
That's 2 no's. & mine makes it 3.
Inquiring minds need to know why not?
Old Jan 17, 2011 | 02:55 PM
bobbyt89's Avatar
bobbyt89
iv heard of this alot atf has alot of detergents in it and will help thin the oil i would say when adding to 16 qts its safe, but i have never done it if you feel the need to try to get your engine extra clean use a full can of sea foam in the oil for 50 miles or so, or go to your local auto parts store and look for a engine flush. if you feel your engine is dirty use a good oil filter not a cheapo fram i say wix/napa gold same filter and change your early real early once or twice my .02
Old Jan 17, 2011 | 02:59 PM
rickf92592's Avatar
rickf92592
+1 on the Seafoam. it is made for the task.
Old Jan 17, 2011 | 06:12 PM
tjbeggs's Avatar
tjbeggs
I might try it with a standard engine but CERTAINLY not on a HEUI engine. BTW Diesel oil has large amounts of detergents in it anyway and diesel engines are much cleaner than gas engine on the inside. I have never seen any gunk or build up on the inside of a diesel engine.
Old Jan 17, 2011 | 06:26 PM
tempforce's Avatar
tempforce
seafoam and products like that are designed for cleaning sludge.
however on gas engines, i have used the atf trick to clean sticking lifters.
prolonging a teardown and replacement of lifters, etc. for thousands of miles.
i have also used stp in a standard transmission to prolong a bearing replacement.
in all cases, all these methods do, is postpone required repairs.
Old Jan 17, 2011 | 06:55 PM
intl1256turbo's Avatar
intl1256turbo
When I got my other 97 with 200k on it.my uncle died and didn't drive it for 5 or 6 years I filled up both tanks with fresh fuel I put a gallon on atf in each tank.I was huge difference on milage a just ran great. Now I do it one a month or so in all my trucks my fuel system lookks like brand new
Old Jan 17, 2011 | 07:03 PM
XBAJBUSX's Avatar
XBAJBUSX
A gallon wow
Old Jan 18, 2011 | 07:22 AM
rickf92592's Avatar
rickf92592
Originally Posted by XBAJBUSX
A gallon wow
ditto!
Old Jan 18, 2011 | 08:49 AM
Muktown's Avatar
Muktown
You can run straight atf so a gallon wont hurt anything. Only thing id worry about with that much atf is dying the fuel red. A trooper pulls you over and dips the tank you may have issues
Old Jan 18, 2011 | 09:05 AM
rickf92592's Avatar
rickf92592
What's the cetane rating of ATF?
maxtruck00
Jul 2, 2014 01:40 AM
Brain's 97 Diesel
Jun 15, 2013 12:03 AM
swampbear
Jul 4, 2012 06:35 PM
Miller
Dec 30, 2006 06:23 AM
Pass The Peas
Oil & Lubrication
19
Aug 10, 2004 02:10 PM
