Greetings,
am in need of help with my 1983 f250 4x4 5.8W M21 4spd
The truck was purchased from a buddy, and i have never heard it run, or even think about running...Truck turns over fine, had intermittent spark....
have replaced
coil
voltage regulator
ignition switch
ignition relay
EEC (unit on drivers fender)
Computer(under drivers seat)
magnetic crank pickup sensor (still shaking head)
i have 8volts at the coil in run, 12 on crank THERE IS NOTHING UNDER THE DIST CAP!!! no star, no points, no vacuum advance... NOTHING!!
this truck uses a "star" on the balancer, and a crankshaft position sensor....
Truck turns over fine, rotor turns fine, shorting test plug lead to ground and releasing does trigger coil to fire (sometimes). any help is greatly appreciated.
I've seen that system. It was causing issues, so it went in the bin, and a standard DS2 ignition system went back in it's place. Been a few years, so I'm not 100% sure on the required steps.....
Of course, if you have to worry about emmission testing, this isn't really an option.
No emissions, its a farm truck really... heck she dont even have any exhaust under her.... =)
i'm runing out of "normal options"
also have disconnected the neutral safety switch and she wont even turn over, ANY ideas i'd be willing to try
I have tried starting fluid, and no stumble or sputter at all.
I called the local parts depot, they have three options for less than 70 bucks.
your opinion please....
1. single vacuum no module
2. no vacuum, no module
3. dual vacuum no module
i'd just go get one and chunk it in, it has the original 2BBL, if i go vacuum, straight manifold, or where??
you want the distributor with the single vacuum advance, the module that mounts to the drivers inner fender, the coil and the wiring that connects them together.
i found an article that was to test the coil, and associated wiring, you shorted out the test plug on the drivers finder, and held it to ground ~1 sec, and release... each time i'd let go, well... 1 out of 10 would light up the timing light...
