6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Yesterday's Hiccup
Old Jan 15, 2011 | 08:43 PM
Larry NCKS's Avatar
Larry NCKS
Yesterday's Hiccup
I hate to say too much here. I've been a strong poponent of the 6.4 and don't want to add more fuel to the fires of the naysayers.
Yesterday didn't flow as I expected it might, however. I was ten miles into the ninety plus miles from the farm to my wife's house when it all happened.
1. Cruise Control kicked out and was inoperative from that point.
2. Truck went to limp mode, no MIL.
3. Drove about five miles, pulled off and shut engine down for a minute or so.
4. Restarted and hit the road.
5. About a minute into restart, cruise again kicks out and engine goes to limp mode. This time there is an MIL.
6. Drove about two miles, pulled off and attatched code reader. Codes P0404 and P1335 present. Reset the MIL.
7. Restarted and immediatley same scenario.
8. Drove another thirty miles. Stopped for a bite. Checked and reset MIL. Codes P0404 and P1335 present - EGR related.
9. After thirty minutes, headed on up the road. Cruise inoperative. No MIL, but could tell we were in limp mode.
10. Drove another thirty miles. Pulled into abandoned service station and shut down for a couple minutes.
11. Restarted engine. All symptoms gone. Cruise operational.
12. Truck normal ever since.
My best guess is carbon dislodged and stuck the EGR open a bit. My question: Was this a harbinger of things to come? Or was it a thing that may happen, but will not necessarily repeat?
Old Jan 16, 2011 | 06:29 AM
senix's Avatar
senix
P0404 X
Exhaust Gas Recirculation
Control Circuit Range/
Performance
This error is set when the deviation in EGR
position is outside the threshold. 10 percent of full range error >5 sec System error, EGR valve, PCM
P1335 X X X EGR Position Sensor Minimum/
Maximum Stop Performance
This error occurs when voltage of the EGR valve
falls below the minimum threshold. 1.3v >2.5sec Wiring, EGR valve
assembly,PCM
Based upon what you are saying I would agree that is was sticking. I take it that you have the old style one still? I do as well and have had no problems at all.
I would take a look at the wiring and connections just to rule that out.
Old Jan 16, 2011 | 08:06 AM
Larry NCKS's Avatar
Larry NCKS
Yes, my EGR is still original. This is the first time I've had problems with it. 68K on the clock. It took me a bit to get my wits about me and realize why my cruise control had become inoperative. Thanks!
Old Jan 16, 2011 | 08:13 AM
senix's Avatar
senix
I can understand that. Limp mode.
orionife
Texas Chapter
May 3, 2012 10:10 PM
XB70
Sep 29, 2011 11:39 AM
MIKE1646
Jun 10, 2010 08:35 PM
PROxac
Jan 26, 2010 06:02 AM
99whiteford
Sep 22, 2009 09:17 PM
