c-6 tranny
Old Jan 15, 2011 | 05:39 PM
rickybobby1977's Avatar
rickybobby1977
c-6 tranny
i have a c6 trans and i was under the truck tightening the left exhaust manifold whan i noticed the shift linkage there is one lever (don't know what to call it) and there is another slightly above it it looks like a spring loaded lever when i pull on it it goes back when i release it can anyone help
Old Jan 15, 2011 | 05:42 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Kickdown lever, sometimes called the "passing gear"
A rod should connect to the lever and to a lever on the carb throttle arm
Josh
Old Jan 16, 2011 | 10:00 AM
rickybobby1977
can you tell me how to hook it up
Old Jan 16, 2011 | 03:04 PM
OrFordGuy's Avatar
OrFordGuy
theeres a metal rod comes off a second linkage peice on the carb and goes down to the lever...there usally clipped in... the carb linkage has the pedal rod and inside that toward the carb body should be another linkage peice that moves loosley if not coonected to the rod but will ru into the pedal linkage when the gas is pressed...the rods do diffeer from motor family to motor family so try ot find the right one but other will fit with slight mods...
