Auto Enginuity
Old Jan 25, 2011 | 08:01 PM
  #31
Zmann's Avatar
Zmann
Good to know ,, I live a few miles from A/E so I had mine fast also !!
Old Mar 14, 2011 | 03:15 PM
  #32
davidkstyler's Avatar
davidkstyler
Originally Posted by tex25025
If you are talking about the strategy of the truck, I think I did stumble upon that once, but I'll have to mess around with it some more to make sure how to get to it. That was during my phase of "playing around with the new toy" with regard to the software.
Just got my software and ran the injector test, all OK! Lots to learn.
Did you find time to look for the strategy on your package?
I haven't had time to go back to the vehicle yet, but does this look like what you found?
"Vehicle Information
Vehicle information shows the make, model, year, VIN, vehicle
interface type, OBD-II type, CAL, and CVN information. If any
enhanced interface options are active, then you may see more module
specific information in the Vehicle Module Information list.
The ECM Information is where you can determine the ECM ID
the ScanTool is communicating with and the CAL and CVN IDs for
it. Only late model vehicles will report CAL and CVN IDs.
The ECM ID will help you determine which control module
your vehicle uses in some cases. For example, Chrysler will use different
ECM IDs for different ECMs. The ScanTool will display this
information if available.
The CAL ID is the Calibration ID of the ECM. Simply put, it’s
the binary fingerprint of the ECM’s current program. Dealers can
use this information to determine what revision of the ECM you are
using for possible reflashing recalls.
The CVN ID is the Calibration Verification ID of the ECM.
This is used to determine who installed the CAL program.
Emissions testing centers and dealers will use this information to determine
if the vehicle’s program was reflashed privately or by a
factory tool."
Interesting that the Smog Guy can see if you have a factory tune or not! Could they fail your smog test for this?
Old Mar 17, 2011 | 10:49 AM
  #33
davidkstyler
Bumping edit up the list.
Old Mar 17, 2011 | 11:22 AM
  #34
Zmann's Avatar
Zmann
that is interesting .. in AZ they don't plug into the OBD port for the 6.0
they just do an opacity test when you hit redline 3 times in a row
I wish they would just use the port to see if it was compliant like they do with gassers redline is a pucker maker
Fastolds
Ford Truck Parts for Sale
Nov 25, 2012 02:10 PM
wosborn
13
Mar 29, 2006 02:40 AM
Earl
May 31, 2002 09:13 AM
dslman
Aug 5, 2001 11:46 AM
