starting problem?
Old Jan 17, 2011 | 11:31 AM
John D in CT's Avatar
John D in CT
" ... those batteries were both brand new 3 months ago "
Have you tried fully recharging them, testing them, and then seeing if your truck starts properly?
Bear in mind that if you fully discharge a brand new battery, it will permanently lose a lot of its amp capacity. (This is less true for deep cycle batteries, and I'm told, Group 31's, which are constructed like deep cycles but aren't labeled as such).
A modern load tester will tell you exactly how many CCA's your batteries have. Voltage is near-meaningless in determining a battery's ability to crank an engine.
Fastbird
Crossovers
Feb 24, 2015 09:51 AM
jimbomac22
Sep 28, 2010 08:38 AM
whadeen
New Member Introductions
Oct 8, 2008 09:22 PM
mikewalsh1
May 10, 2006 05:29 PM
