you may need to replace the accelerator cable......or try pulling it off and greasing it, but thats just temp if you have broken strands, or the liner in the sheath is wore through
so maybe cleanin up the throttle springs on the linkage with some carb cleaner the follow with some white lithium and spray it also down inside the throttle cable and the tv cable. would that work? and if not, if i have to get a new throttle cable where like an oreilys? and how much do they run?
pretty much yea...if you take the cable off throttle bracket...and the bracket is nice and loose and works like it should then its a safe bet the cable is toast....
the grease may or may not work...just depends what is causing the bind....if its broken strands, nothing is going to help......
i just noticed the 6" lift.....is that body or suspension ?
