35's on a 91 f150 with 2.5" leveling???
I have a 91 F150 with a 2.5 inch leveling kit on it. I just purchased a set of wheels and tires. tires are shot, im looking to buy a set of new tires, i'd love to put 35's on it but i need to know if it will fit and if it would tear anything up because of how big they are? I think they'll fit because the 33's that are on it now fit kinda small in my opinion, i dont much care if i lose some power or gas mileage just wanna make sure it wont tear my gears out.
Measure the diameter of the worn out tires with a tape measure. I'd be willing to bet they aren't a true 33"
Many F150 drivers have rubbing with 33" tires, so I'd imagine 35s could be problem with just a leveling kit. It'll probably depend how wide of a tire you go with too. Also, I wouldn't do it without at least 3.55 gears, but even that isn't really the best scenario.
Alright after seeing that pic i think im going with 35's. I personally would like a full wheel well rather than a bunch of space. Love the looks of huge mean looking tires. Plus I plan on getting a bigger lift in the future so i think the 35's with a full wheel well would be good for now and still look good when i get a bigger lift...saves me buying tires twice. and by the way i have 16x8 wheels now...i have 2" spacers on the way, they'd still work right? Cuz with my old 12.5" wide tires rubbed on the inside when i turned pretty sharp, would this fix it with the 35x12.5's?
Tire size and rim width/offset go hand in hand. I run 32x11.50s on 9" wide rim with 4" back spacing and i have no issues on an 89. 33s would not fit(well they would but the back edge was close on full lock). 33s would be fine with a leveling kit. If you have anything less than 4" back space you will rub the radius arm. Anything more or a wider rim/tire combo chances are you will be close to the fender on full lock/bump. I think it will come down to the offset of your rims and the true size of the tire. Most tires are about 1" diameter less than claimed at the edge.
