99 mazda auto no reverse
Old Jan 13, 2011 | 08:38 PM
redneckfarmers's Avatar
redneckfarmers
i have a 99 mazda b 3000 4x4 3.0 liter moter automatic was backing up one day and lost reverse all foward gears are fine except it has no back pressure in 1st but going foward in first works fine any help would be great
Old Jan 14, 2011 | 07:39 AM
03 Maz B23's Avatar
03 Maz B23
Can't guarantee this is your problem or if want to attempt but here is good link. Have also read that solenoids can cause issues too.
Common Fix For 4r55e / 5r55e Transmissions With A Bad Separator Plate And Valve Body Gasket .: Articles
Old Jan 14, 2011 | 07:51 AM
tomw's Avatar
tomw
I think your band strut fell out of place. That would kill reverse and 'Low' engine braking.
If you want, you can try to put it back in place by removing the servo cover, using a phillips to maneuver the band into place, and small nosed pliers to put the strut back in place, and then replacing the servo and rod. It CAN be done if you want to avoid pulling the transmission. The adjustment for that band is made by lengthening or shortening the servo piston rod. Some may have adjustments with 'E-clips' on the end of the rod at the piston.
Other than that, park where you don't need reverse...
tom
Old Jan 15, 2011 | 04:33 PM
redneckfarmers
what is the chances of it being the reverse servo 0 rings being bad ?
Old Jan 15, 2011 | 05:17 PM
Diesel_Brad's Avatar
Diesel_Brad
check your fluid level.
chicagodragon
Nov 28, 2010 06:09 PM
f250_superduty2001
1997 - 2003 F150
Jan 21, 2007 09:43 AM
lf_9659
Dec 26, 2003 12:29 PM
