Truck began stalling while driving, now wont start. PLEASE HELP!
I will assume you meant 80-100 miles not 100k. If you really drove that much you would be way over 350k by now. Furthermore, you are not the only one that drives those kind of miles. There are millions of people out there driving as much or more than you, that pull as much or more than you, that have NEVER had an egr issue.
You are speaking from your point of view? What, all three of them! Wait, you are a 6.0L Guru and in your infinite wisdom you deleted your EGR. Has to be the best way, right? Hold on now you recommend the bullet proof system, after market, because the factory one is junk right? No, hold on again, you know tons of people likeTex25025 the drive tons of miles and his is just fine, nothing wrong with it at all, stick with the factory EGR?? Make tons of sense? The choice is clear! Are you kidding me?
But that’s not all; you even know how we maintain our truck, EGR Failure “Probably due to maintenance issues”?
Maybe some more of your guessing? Want to talk about maintenance, we tow commercially and are subject to level 1 DOT inspections at every weight station, we get inspected multiple time per week by inspectors just looking for a reason to take our equipment out of service. We have to keep our equipment maintained in perfect order, we can’t afford to break down, PM is paramount for our business.
“You assume that there is no way that it can function properly for extended miles.”
Hello?? Our truck is used commercial and fleet maintained and you are clueless to its maintenance history. How can you make that statement?
“ I will assume you meant 80-100 miles not 100k. If you really drove that much you would be way over 350k by now.”
Good Guess again, but wrong. We purchased our used about 3 1/2 years ago with 29k miles, so we in fact drive 80,000 to 100,000 miles per year commercially pulling a 5th wheel trailer the entire time, so the truck does get extreme use. Not light recreational towing like 5k per year maybe?
“Furthermore, you are not the only one that drives those kind of miles. There are millions of people out there driving as much or more than you, that pull as much or more than you, that have NEVER had an egr issue.”
I am sure you know each and every one of them personally? Could this be another one of you well documented theories or just another guess?
My opinion is the delete is the best way, fact based on having to replace three of them. So unless money is not an issue and you don’t care if you break down, then go factory or aftermarket. If you just need your truck to run well and never want to look back at it again, delete it.
Certainly a properly deleted EGR system will most likely not cause you issues again - in this area. But that does not mean that the EGR system can not be made reliable. There are a number of people here that tow quite a bit with their EGR system intact and with high horsepower tunes and do not have problems. I agree that they are in the 100k - 150k mile range, so they have not demonstrated the HIGH mileage that you have. However, they have no indication of issues that would make them believe that your kind of mileage is not possible. I guess that is not hundreds of data points, but if it can be done by one, it can be done by the majority (IMO anyway). I belive that you can certainly have "fluke failures" in vehicles, but it is hard to have "fluke reliability".
Texans is speaking from the background of his experience and this forum's input from users and techs. It is a fairly extensive base of information. Who knows if it is more or less than yours, but it is certainly more extensive than operating even a 10 or 12 vehicle fleet. One of the key things (I assume) that puts him in the camp of "keeping the egr system" is a thread where several techs have posted up on the subject. In that thread, they tell us that they have observed cases where deleted egr systems have caused the cooling fan to not operate properly. This can clearly be an issue that has significant consequences. This was a big factor for me to decide to keep my egr system anyway.
The maintenance that Texans describes is most likely centered around the coolant system. We (and all the other 12+ 6.0L forums) all talk about coolant system flushes every 50k miles. Few people do that, especially commercial fleet owners that are trying to be frugal. Another important maintenance issue is the use the proper coolant and adding a filter. Also in the discussion of maintenance and reliability is the importance of watching the temperature difference between the coolant and the oil. Lastly, when you add "testing the coolant for nitrites" you generally don't find folks that do this. If you do these things, then great, but most new comers to the forum do not.
It is always a plus to have fleet owners and operators AND commercial users on the forum. Please do not take any of the posts personally. I know Texans did not mean it that way. He was no doubt responding to your last statement in post #15 where you say that you have seen every issue possible with the 6.0L. That comes across as a pretty bold statement that tends to initiate bold responses. Anyway, stick with us, it is a great place!
the coolers made by bullet proof are very well made. If I had a need a fleet to remain stock in form this is were I would look.
complete delete kits can fail too. they can still leak coolant, externaly , but if we are counting fails its still counts.
as to what the right awnser is... thats for you to awnser for your own needs. all you can do is take the advise , opinions and facts and pick from there.
The EGR failures are a thing of the past from many different causes.
If you were to reset the clock with,
- complete VC-9 flush (an iron cleaner)
- Install coolant filter
- Maintain coolant properly (50k changes, nitrite test)
- Then replace EGR cooler (the BulletProofDiesel one is widely recommended)
- Replace Oil cooler.
There should be no more failures.
When I first bought the 6.0, (a bit more than a year ago) the consensus was this vehicle was so bad it is in need of $10,000 of mods.
Well, that is just not true.
Improperly maintained, even $10,000 might not be enough.
But I do have a very well equipped set of labs and engineers and technicians within a 15 minute walk.
And within 2 hours, more auto engineers and suppliers than I know what to do with.
Funny what you can find out just by asking.
I guess thats just what I see here in one shop in texas dallas / ft worth metro and the ratio just doesnt hold up in canada.
may the fail rates here are caused by all the gun powder in the air here.
Old cheese!
I am almost certain that the failure rate is higher because of higher thermal stress in them southern climes --- and the fact that fewer people up here are using the 6.0 to tow overweight trailers.
What we gain in less thermal stress... we lose in severe salt corrosion issues.
You should see the brake / undercarriage / exhaust / etc. repair bills I have.
Oh.. the factory muffler split its seams from rust.
Again, you are stating this based on the fact of your truck, and your truck alone. You are not doing any research to see if maybe it's something your doing, or maybe you just got a bad truck. To say "oh, I had to replace three of them. So it's fact that they are crap, and you should get rid of them. What light is not turning on in your head to see that maybe, just maybe there are others out there that do run the egr system with 200k+ without any problems. Oh, wait I forgot your d*** is bigger than everyone else right? Your the only one that tows commercialy with a 6.0 right?
