New here...
Old Jan 14, 2011 | 11:56 PM
kjvforme's Avatar
kjvforme
Yeah strange about the cooling capacity, my owners manuals says 18 quarts.
Old Jan 15, 2011 | 06:36 AM
jowilker's Avatar
jowilker
Dean the vin number is on the top of the passenger side frame rail near where the front axle passes under and also under the cab. It IS there, and can be a bugger to find sometimes.
When I did a 1st fill after my rebuild it took most of 5 gallons, so 18 qts is about right.
I recommend taking a few minutes and mixing your antifreeze with grocery store distilled water 50/50 before putting any in.
We had some of the best tasting water on the farm where I grew up, but after a few years everything that had it in the cooling system looked like mud. The distilled water shouldn't add minerals that can do that, and is about a buck a gallon.
John
Old Jan 15, 2011 | 08:05 AM
deanbhula1's Avatar
deanbhula1
Hmmm weird. I used pre mixed but I could only get about 2 and a half of the gallon containers to go in.
Old Jan 15, 2011 | 10:46 AM
deanbhula1's Avatar
deanbhula1
Ok so this is what the door plate is saying:
F25JD54664469
128 Y F250 281 F 26
7500 114 3600 61
Old Jan 15, 2011 | 11:08 AM
kjvforme's Avatar
kjvforme
F25JD54664469
128 Y F250 281 F 26
7500 114 3600 61
F25= 2wd F-250
J= 223 CID, 1V carb, 114 HP, 3600 RPM
D= Dallas, Texas assembly plant
564469 (one to many numbers) Jul 64
128=Wheelbase
Y= Silver Blue (Not sure on this one)
F250= Model
281= 2 = Medium Blue Crush Vinyl & Medium Blue Wicker Pattern Vinyl / 81 = 81A Standard Cab.
F= 4 Speed manual transmission
26= Not sure but could be a 4.88 ratio
7500= GVW
114 = Engine Horse Power
3600 Engine rpm
61= Dallas,Texas District Sales Office (dealers would have ordered from the is office for Northern Texas (except Panhandle).
Old Jan 16, 2011 | 12:33 AM
deanbhula1's Avatar
deanbhula1
So u got all that from the ship manual?! I think I will be obtaining one but for a 64 now haha. Oh by the way...what would be the diff capacity??
Thanks
Old Jan 16, 2011 | 05:56 AM
spurredon's Avatar
spurredon
Thanks
If you are only refilling the radiator and not the block, that would be your difference. There is a bunch of coolant already in the engine if you have not had it apart. As John said, from rebuild it will take over 4 gallons.
Old Jan 16, 2011 | 09:12 AM
deanbhula1's Avatar
deanbhula1
Oh ok. That's probably it then.
Thanks
Old Jan 16, 2011 | 11:52 AM
jowilker's Avatar
jowilker
Did you price check 2 gallons of premix vr 1 gallon unmixd and 1 gallon grocery store water.
Today Advance Auto Creedmoor store online
Prestone Extended Life Antifreeze/Coolant (1 Gallon) $14.99
Prestone 50/50 Ready-to-Use Prediluted Extended Life Antifreeze/Coolant $11.99 X 2 = $23.98
1 gal. Antifreeze $14.99 + 1 gal distilled water $1.00 $16.00 total VR $24.00. $8.00 a gallon for their water.
Antifreeze @ $15.00 a gallon, what the hello is going on with that, seems like $9.00 last time I checked.
John
Old Jan 17, 2011 | 12:53 AM
deanbhula1's Avatar
deanbhula1
I just used walmart antifreeze because I'm still working on the truck and just needed basic stuff to get by. And the walmart premixed price was 6 a gallon
greenbox53
Aug 19, 2013 06:43 PM
camp nh
New Hampshire Chapter
68
Feb 1, 2013 06:07 PM
alamofirefighter
New Mexico Chapter
17
Apr 21, 2008 07:21 PM
Rustipup
New Member Introductions
Dec 31, 2006 03:13 PM
finnur
Jan 18, 2005 05:25 PM
