New here...
Old Jan 13, 2011 | 03:54 PM
deanbhula1's Avatar
deanbhula1
New here...
hey,
im new to this forum...but i have a 1961 f250 with the 223 motor and i was wondering if there is a way to find the specs for the truck? like the fluid capacities?
thanks!
Old Jan 13, 2011 | 04:45 PM
jowilker's Avatar
jowilker
Bill da Number Dummy should be along shortly gladly providing that info for you.
Hang tight.
John
Old Jan 13, 2011 | 10:32 PM
SuperSabre's Avatar
SuperSabre
Owner's Manual is available for your truck
Several vendors, one of which is LMC Truck, sell reprints of your original owner's manual, which contains the relevant information you're looking for regarding fluids plus a lot more. LMC sells the manual for $9.95 + ship. www.LMCtruck.com.
Old Jan 14, 2011 | 07:09 AM
spurredon's Avatar
spurredon
Welcome to the forum. If you are going to get serious about working on your truck, a shop manual would be the way to go, much more info than owner's manual. They are also available in various places. There's a repo available on Ebay BIN $50 plus shipping. Besides, if you get the shop manual you will have many more questions!
Old Jan 14, 2011 | 08:01 AM
Old_Ford_Man's Avatar
Old_Ford_Man
First let me say welcome to the forum good group of people that are always willing to help. John that was a good one,
Old Jan 14, 2011 | 10:38 AM
Mike G's Avatar
Mike G
Welcome aboard, what fluid capacities are you after? I never use those, if it's correctly filled, it's good, I'm not going to drain and measure and put back just to compare...
--Mike
Old Jan 14, 2011 | 12:28 PM
macgiobuin's Avatar
macgiobuin
Welcome from Chattanooga, Tennessee.
Old Jan 14, 2011 | 12:37 PM
kjvforme's Avatar
kjvforme
I have a 61 shop manual what were you looking for?
Old Jan 14, 2011 | 01:42 PM
deanbhula1's Avatar
deanbhula1
i was wondering the:
Coolant Capacity
Oil Capacity
Tranny Gear oil capacity
Diff Capacity
Thanks!
Old Jan 14, 2011 | 02:10 PM
kjvforme's Avatar
kjvforme
Coolant Capacity
Oil Capacity
Diff Capacity
Thanks!
From my 62 Owners manual
223 CID
Coolant 18 Quarts
Oil Capacity 5quarts without filter 6 quarts with
I need to know the transmission code off of the Vin Plate
I need the Axle code off of the VIN plate located on the inside of the glovebox.
Old Jan 14, 2011 | 02:37 PM
deanbhula1's Avatar
deanbhula1
I just checked the glovebox and there is nothing there...will the vin that u get on the door? If so it is F25JD564469
Old Jan 14, 2011 | 02:45 PM
kjvforme's Avatar
kjvforme
Ok by the door tag you have a 1964 truck
F25=F250 2wd
J= 233CID
D= Dallas, TX
564469 = Jul 1964
You might want to verify the VIN thats located on the right frame rail just in front of the cab.
Old Jan 14, 2011 | 03:27 PM
deanbhula1's Avatar
deanbhula1
I cannot find any numbers on either frame rail. Only thing that has numbers is the plate on the drivers door. And I figured it was a 61 cause the last thing on that plate says 61. I knew how to read the vin till the assembly plant but didnt know the numbers after the D. So I guess it's a 64 haha. But it has the 4 speed manual transmission if that helps...
Old Jan 14, 2011 | 03:43 PM
kjvforme's Avatar
kjvforme
The VIN is stamped in on the top surface, you'll need to take a wire brush to it to find it. The 4 Speed Warner transmissions capacity was 8 pints. On the door tag there should be a two digit axle code number, it should be behind the letter F which is the 4 speed transmission code.
Old Jan 14, 2011 | 04:26 PM
deanbhula1's Avatar
deanbhula1
Oh ok. Well I'll check and get back to you...I looked up and down the frame rails but didn't see amything. Maybe if I take a brush to it. Haha. Oh and also you said 18 quarts for coolant, that seems a bit much because I think last time I filled the coolant, I think only 2.5 gallons fit...
