new ficm
Old Aug 17, 2013 | 10:39 PM
greenbox53's Avatar
greenbox53
new ficm
do I NEED TO GET A NEW ficm PROGRAMED before installing
Old Aug 17, 2013 | 11:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Brand new from Ford? Yes. A half-shell from Ford or International? No.
Most remans do not need programmed either.
Although most of us use Ed @ FICM Repair.com - Your Source for FICM Repair which come pre-programmed, either using your existing FICM or thru exchange.
Josh
Old Aug 19, 2013 | 06:10 PM
greenbox53's Avatar
greenbox53
FICM
My FICM is from international. What is a half shell
Old Aug 19, 2013 | 06:22 PM
Bullitt390's Avatar
Bullitt390
A half-shell just replaces the power side, the other side (which usually doesn't fail) contains the LOGIC side.
So, long story short, instead of wasting money buying the whole thing you can save by buying the half-shell.
However (short story gets longer) the main problem still persists of the power side eventually failing, so many use Ed @ FICMREPAIR to upgrade the FICM.
BPD makes a new half-shell that is hot-rodded.
So, I am guessing you may have purchsed an entire FICM from International (didn't think it was still available) you'll need to have Ford install the FICM and program it.
Josh
Old Aug 19, 2013 | 06:38 PM
greenbox53's Avatar
greenbox53
FICM
Bought it on ebay about 3 yrs ago. It is the same as the one on my truck.
would it work if I just switched power sides? My Voltages were 48v with key on. Drops to 19 while cranking. Seems like none of the injectors are firing.
now I cannot get any voltage reading from FICM. I am assuming that is what needs replacing. Before this my truck would start in the morning after numerous cranks. It would run rough for about 1 min. spit out black smoke ,then clear up and run . It would start after I drove it just fine. It got progressively worse . Now it will not start at all
Old Aug 19, 2013 | 06:43 PM
Bullitt390's Avatar
Bullitt390
That would work swapping half-shells, just have to make sure you match 4 screw to 4 screw or the older 7 screw to 7 screw.
Josh
nance459
Apr 20, 2015 04:44 PM
iggy2
6.2L V8
Sep 16, 2011 05:40 PM
skidooman
2009 - 2014 F150
23
Feb 7, 2010 11:37 AM
DJfamily
6.4L Power Stroke Diesel
37
Jul 30, 2007 08:40 PM
