Just got back from GA with the console and that might be a fairly big issue. Mine has cupholders in the front AND the rear which makes it about 5 inches longer than the consoles without the rear cupholders. That puts the front of the console pretty much in the front dash if you move it forward enough to clear your sub box since it touches the current center seat.
yeah that could be a potential issue i guess hmmmm... can you buy just the rear panel?
If I could find a parts fiche I could tell you for sure but it's just labeled as the console's rear trim panel. Might want to try find a console at a pick and pull to avoid a $300 price tag. Or do like me and take the center seat out and replace it with something. I put a custom sub box with a pair of 10's and a alpine amp there with custom brackets.
I think if you have a local ford group like I do in Arizona AZPSG you could offer up the swap and someone would definetly change rear panels with you
not sure what all is involved but it shouldn't be hard
