Looking for Door Latch '49 f1
I should have the right side door latch, and maybe even the left side. I'm still working on the hood trim parts for you. I found them, but need to clean them up a bit.
However, you might be able to get yours to work. Remove it from the door and soak it in some lubricant, then move it around after a good soaking. You can also pop the tabs on the back of the latch and disassemble it completely. Then you can clean it more thoroughly. I'm currently doing a similar procedure on a left side door latch (with a lock) from a 5 Star Deluxe.
Let me know if you want me to hunt down a pair of latches, or at least the right side.
jhaas63
07-29-2014 08:37 AM
perpetualjon
06-01-2014 10:21 AM
suds
04-12-2013 06:43 AM
