I need a 4x4!!!!!!!!!!!!!
Old Jan 15, 2011 | 10:25 AM
  #136
92nite351's Avatar
92nite351
i love my A/T's...these General Grabber AT2's are the best winter tire i have ever had.. and ive had bfg's and all... the secret to good luck in winter is use your head no matter what tire what width height whatever. so good luck to u all this winter and bill go 4x4 anyway. just makes 4 a fun project.... have fun with it bill..
Old Jan 15, 2011 | 11:42 AM
  #137
hodges710's Avatar
hodges710
Originally Posted by Samsonitesamsonite
Tread design is key, but if you give me two tires of equal tread design, the narrower of the two will ALWAYS have better traction in the snow and ice.
Thats not true but hey, if it is your preference on a smaller tire, than its your money when it comes to the purchase
Old Jan 15, 2011 | 12:43 PM
  #138
GBuckert's Avatar
GBuckert
Originally Posted by fatdan460
looks like what forest patrol/conservation vehicles used to use. my buddy had an old jeep cherokee that was an ex patrol in that color.
Exactly, it was used in the Big Horns for one of the Forest Service law enforcement officers. He didn't actually drive it much other than to haul a horse trailer out to the mountains.
Old Jan 15, 2011 | 01:24 PM
  #139
Samsonitesamsonite's Avatar
Samsonitesamsonite
I concede the fact that in the real deep stuff maybe not, but all other times, it is true. In all honesty how often do you have to drive on roads that have over a foot of snow. Out here, the main roads are plowed normallyMore PSI where the rubber meets the road in normal winter driving conditions DOES help.
Old Jan 15, 2011 | 02:52 PM
  #140
CWPottenger's Avatar
CWPottenger
Often in the country... plows come once maybe twice if your lucky and then any time the wind blows the drifts can get huge... Weight has more effect than anything else to a specific tire design...
My work van for example... winter hits it wil slip and slide on a single snow flake(new tires).... I add 1000lbs to the floor over axle and the van tracks straight and predictable even over snow and ice covered roads... The best ice/snow tire in the world won't help if not enough force to keep it on the ground, that is one of the main reasons why front wheel drive and 4x4 go better in snow is the WEIGHT over a drive tire...
Old Jan 15, 2011 | 04:25 PM
  #141
fordman75's Avatar
fordman75
You are right! But I'd still rather have a 4x4 with weight in the box over a 2wd truck with weight in the box!!
Old Jan 15, 2011 | 05:43 PM
  #142
92nite351's Avatar
92nite351
x2 my friend x2
Old Jan 15, 2011 | 05:53 PM
  #143
FORDF250HDXLT's Avatar
FORDF250HDXLT
his comment was 100% accurate actually.
you could take his comment 1 step further by replacing the last words "snow and ice" with "all surfaces besides "deep" mud".
even then,the wider tire isn't getting better traction,it's just not letting the axle sink as much as skinny tires so you don't get hung up.
tire width and traction is often misunderstood.
wide tires do not help in "deep"(a foot or more) snow either,like they do in mud.your going to sink in a foot of snow no matter what.
so you'll be just as hung up as if you had skinny tires,but with less traction.
if you had a light 4wd car and wanted to try driving in 2-3 feet of snow,in this case wider tires might be the better choice,as your only hope would be to try and stay up on top.again even in this case,it wouldn't be for better "traction" even still,but just to keep you from sinking.
Old Jan 15, 2011 | 07:23 PM
  #144
L. Ward's Avatar
L. Ward
The BIGGEST key in driving on snow/ice is not overpowering the throttle. Tire design can help, but too much throttle and it doesn't matter a bit what tires you have...
Some examples...
  1. Last week, we got hit in SC with 3" of snow here topped by another 1/2" of ice. Everything basically shut down. I had to run a couple work errands and stop by the fire station and check in. Pulled out the F250 which has 315/75/16 Maxxis Mudders on it, locked the front hubs and tooled on down the road. I engaged the front axle 3 times in a 40 mile round trip... all 3 times were on hills (2 headed to Aiken, 1 headed back) where the back end wanted to try and break loose a bit. Other than that I left in in 2wd the entire time, the only weight in the bed being a ****** strap that I threw in to have just in case.
  2. 2007 Valentine's Blizzard, I was moving an oversize load and got shut down in Lodi, Ohio at the truckstop. The following morning I woke to 15" of snow on the truck. Around 11am, my pilot car and I pulled out of the unplowed truck stop and left. This was with drive tires with 5/32 left on the tread (minimum allowable is 2/32) and only 4000lbs on the lowboy (empty bag house). While everybody else with full loads on their trailers were busy getting stuck and flooring the throttles, I very gently worked the throttle and up thru the gears to get moving and on down the road.
  3. 1997 Central Indiana got hammered with 12"+ of snow. Howard county declared a state of emergency and the EMA asked for volunteers with 4wds to help transport medical staff to the hospital and check the back roads so they could get ready to send out the plows. At the time I had a 78 Bronco with a 460 and 40" swampers... the thing was a complete turkey on the light stuff in town, as soon as I got out on the unplowed roads the swampers cut a nice deep path and pulled themselves right thru with no problems, including busting thru several drifts that were 2-3' deep.
After 2 million miles plus driving, and living in the midwest from 1989 to 2007 I could list more examples, but I will just stick with these. All 3 examples were different tires and weights, the one thing in common was all 3 times I only used the amount of throttle needed and not a bit more. As a general rule of thumb, when it comes to driving in the snow, you can pretty much count on the following.
  • Use only the amount of throttle needed to get the vehicle moving and keep it moving. If you are spinning you are using too much (yes sometimes it can't be helped, but try and avoid it at all costs)
  • In light snow, in town, or slush conditions, a skinny tire is the way to go. You will have maximum weight to traction ratio. A dedicated snow tire is even better, but a set of narrow tires with a good tread pattern will do fine the majority of the time.
  • Weight can help, but it can also hurt too. Remember the law of inertia an object at rest wants to stay at rest, an object in motion wants to stay in motion. Translation, 500lbs of sand in the bed may seem to get the vehicle moving easier, but its also an additional 500lbs you have to bring to a stop. I have seen many trucks with sand, blocks, etc slide thru intersections because the weight overcame what little traction there was.
  • 4wd does not equal 4stop. Every year when I was driving, I saw way more 4x4's in ditches and the medians because the driver thought the 4wd was so great, they could try and cruise like they normally did in dry conditions.
Old Jan 15, 2011 | 09:24 PM
  #145
hodges710's Avatar
hodges710
Some people still fail at what they think makes a good tire. Some get it right when talking the difference between a mud tire and a all season/ or just a good winter tire. A tire can be as wide as you wish and still be better than the smaller tire, how this is so is the sipes. Mud tires dont have them, all they have are some big lugs/blocks while and all season and/or a snow/winter tire has blocks too but smaller in size but the whole difference is the sipes that are made into the rubber. So small tire are NOT the better tire and I dont care how much snow you want to talk about. Has anyone ever took alittle air out of the tire when they got stuck in snow, lol well what that does is make the tire/s wider to get the bigger bite.
Old Jan 15, 2011 | 09:27 PM
  #146
hodges710's Avatar
hodges710
[quote=L. Ward;9829903]The BIGGEST key in driving on snow/ice is not overpowering the throttle. Tire design can help, but too much throttle and it doesn't matter a bit what tires you have...
Some examples...
Well residents in SC can barely drive in the rain
Old Jan 15, 2011 | 09:56 PM
  #147
L. Ward's Avatar
L. Ward
Surprisingly enough, the whole trip I didn't come across anyone in a ditch... by the same token tho, there was almost no traffic out either... I think the majority of folks stayed home and off the roads, considering the majority have no snow/ice experience it was probably for the best too.
Old Jan 15, 2011 | 10:28 PM
  #148
CWPottenger
I'm with ya... I love my AWD and my 4X4
Old Jan 15, 2011 | 10:46 PM
  #149
70torino429's Avatar
70torino429
In all honesty how often do you have to drive on roads that have over a foot of snow. .
Almost never on the main roads. Parking lots and side streets it does happen though.
I remember offroading not that long ago in a Fullsize blazer with the 265's. Did great until this one hill that had a bend in it. What a cluster**** to try to get up it. Finally we got out after letting a good amount of air out of the tires. I know with Ford's dinky little 235's we would've gone nowhere. I think wider tires up to a reasonable point don't hurt you assuming they've got a good tread design and aren't worn out.
Old Jan 15, 2011 | 11:14 PM
  #150
minnesotafisherman's Avatar
minnesotafisherman
Bill, I'm in the same boat as you. I have a '92 F-150 that is only 2WD here in northern Minnesota but I loaded the bed up with 6, 60 pound sandbags, 360 pounds... and put some Firestone WinterForce tires on the back and I rarely slide around like I used to at the beginning of this winter, when I had no weight in the bed whatsoever. Even at icy intersections, I can easily come to a complete stop without sliding in my truck. And my ABS don't even work! I just ease on the gas real slowly when it is icy and I can get going from a dead stop with no problem. I have made it through half of this winter without getting stuck once, but I am still making the 2x4 to 4x4 conversion this summer. I plan on getting a plow for my truck, for next winter as by then I will have 4x4, and the ability to pull people out.
