You stated you had the 85hp tune. I assumed you were running it. For a stock turbo, these readings are in the normal range. You could bump the boost up with a couple simple mods, but I'd wait until the gauges are in.
Can you configure the tuner to read "standard" equivalents for the readings?
You stated you had the 85hp tune. I assumed you were running it. For a stock turbo, these readings are in the normal range. You could bump the boost up with a couple simple mods, but I'd wait until th gauges are in.
Yes, i was running the 85 tune. I hadn't researched what stock boost without a tune was, just did a couple searches, seems to be in the 17-18 range.
I wanted to check mine and make sure I was about where I should be.
As far as switching to psi, i'm researching that now.
1 Kpa (Kilopascal) = 0.145037738 Psi (Pound Per Square Inch)
So i'm assuming the manifold pressure would be my actual boost.
144 x .145037738= 20.88 psi.
Sound about right for an 85hp tune?
It depends on if it was manifold gauge pressure or manifold absolute pressure. The MGP is what your MAP sensor is seeing and absolute pressure us your EBPS.
that was the mgp,
anything else you recommend besides what duck posted for a base tuned truck?
besides the offroad pipe, lol. I shoulda never went with the muffler, lol
I would get some gauges and some miles on her and see what you think. Sometimes your initial thoughts change as you get used to how it drives and runs.
just figure if i'm going to order that other little mod, i might as well get some other stuff with it lol
Didn't know if based on what duck said, if i needed it or not.
how much to send me that delete pipe?
You will depending on where you go with tuning and other mods. Just wanted to be up front that is was created to cure a problem so until that problem exists don't worry about it.
