Decipher data log.
Old Jan 12, 2011 | 07:57 AM
beefcake's Avatar
beefcake
Decipher data log.
I did some logging with my predator, don't have any gauges yet, but figured i'd look at some of the paramaters.
it's snowy out, and roads were crowded, so i couldn't get on it a ton, but i put it in 4wd and hit it on the back stretch of the dealership.
it's cool out 15 degrees or so.
I did one little wot blast going halfway through second
trans temp was about 110 degrees
inj pressure (i guess this is where the 1211 code comes from?) was 17, i believe mpa?
i did 2 manifold pressures, one was absolute manifold pressure and the other was manifold gauge pressure
during lite throttle driving, the abs mp would stay around the low 100's and the manifold gauge pressure would stay about 10% of that roughly
140kpa/13kpa
at wot, the abs mp went to about 240kpa and the manifold gp went to 140kpa
anyone able to break the info down? to be honest, i'm not sure what i'm looking at on this thing, lol
Old Jan 12, 2011 | 08:35 AM
beefcake's Avatar
beefcake
I found a kpa to psi conversion
1 Kpa (Kilopascal) = 0.145037738 Psi (Pound Per Square Inch)
So i'm assuming the manifold pressure would be my actual boost.
144 x .145037738= 20.88 psi.
Sound about right for an 85hp tune?
Old Jan 12, 2011 | 08:57 AM
mueckster's Avatar
mueckster
Based on the conversion, I'd say those readings are pretty normal.
Old Jan 12, 2011 | 09:03 AM
beefcake's Avatar
beefcake
normal for stock? or a base tune?
I have the rifraff filter mod and 4" exhaust. Not sure how that affects boost if at all.
Old Jan 12, 2011 | 09:17 AM
mueckster's Avatar
mueckster
You stated you had the 85hp tune. I assumed you were running it. For a stock turbo, these readings are in the normal range. You could bump the boost up with a couple simple mods, but I'd wait until the gauges are in.
Can you configure the tuner to read "standard" equivalents for the readings?
Old Jan 12, 2011 | 09:20 AM
beefcake's Avatar
beefcake
You stated you had the 85hp tune. I assumed you were running it. For a stock turbo, these readings are in the normal range. You could bump the boost up with a couple simple mods, but I'd wait until th gauges are in.
Yes, i was running the 85 tune. I hadn't researched what stock boost without a tune was, just did a couple searches, seems to be in the 17-18 range.
I wanted to check mine and make sure I was about where I should be.
As far as switching to psi, i'm researching that now.
Old Jan 12, 2011 | 10:11 AM
duck fan's Avatar
duck fan
Because racetruck
Without some sort of boost fooler like the Riffrraff OCR, you won't see much over 20-22 psi. Above 21 the PCM starts to defuel
Old Jan 12, 2011 | 10:18 AM
beefcake's Avatar
beefcake
Again, not looking to go crazy, but that seems like a good mod. Is there anything else recommended for about where i'm at now?
Old Jan 12, 2011 | 10:37 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
It depends on if it was manifold gauge pressure or manifold absolute pressure. The MGP is what your MAP sensor is seeing and absolute pressure us your EBPS.
Old Jan 12, 2011 | 10:41 AM
beefcake's Avatar
beefcake
that was the mgp,
anything else you recommend besides what duck posted for a base tuned truck?
besides the offroad pipe, lol. I shoulda never went with the muffler, lol
Old Jan 12, 2011 | 10:43 AM
Riffraff Diesel
PREMIUM SPONSOR
I would get some gauges and some miles on her and see what you think. Sometimes your initial thoughts change as you get used to how it drives and runs.
Old Jan 12, 2011 | 11:04 AM
beefcake's Avatar
beefcake
just figure if i'm going to order that other little mod, i might as well get some other stuff with it lol
i may still load the 110 tune and try it too...
Old Jan 12, 2011 | 11:11 AM
Riffraff Diesel
PREMIUM SPONSOR
Remember that you won't need the OCR until you get over the 23psi mark. No reason to buy it if you don't need it, unless you really want to
Old Jan 12, 2011 | 11:16 AM
beefcake's Avatar
beefcake
Didn't know if based on what duck said, if i needed it or not.
how much to send me that delete pipe?
Old Jan 12, 2011 | 11:29 AM
Riffraff Diesel
PREMIUM SPONSOR
You will depending on where you go with tuning and other mods. Just wanted to be up front that is was created to cure a problem so until that problem exists don't worry about it.
Riffraff Diesel: MBRP 4" Single Muffler Delete Pipe
