Why oh why so little boost!!!??? :(
Old Jan 11, 2011 | 09:25 PM
deceptichop's Avatar
deceptichop
thank you fellow IDI brotherhood members for opening my thread.
So here we go, I brought my truck over to FidyDiesel in Concord Ca. I have a 1994 7.3 with factory turbo with 190k miles with original injectors and IP.
I wanted to raise my boost to 13. So I installed a brand new Autometer boost gauge. After a few pulls, the boost showed that I maxed 5psi at factory settings.
We then proceeded to shorten the rod (for more boost) but the rod snapped in half. So then we had to get a brand new assembly and rod. After a few pulls, it stayed at 5. And finally we just said **** it, we ended up just wiring the wastegate totally shut. And we were fully aware that can spell disaster. And after a few final pulls, only PEAK 7 psi
Whats happening? I dont think there are any exaust or boost leaks. I have a KILLER homade cold air intake. What gives??
any thoughts/theorys would be greatly appricatied
Old Jan 11, 2011 | 09:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Two thoughs.
What are you running for exhaust?
How much is the fuel turned up?
The stock down pipe and exhaust system with a muffler will kill the boost.
Heat is also a required element to make boost.
Old Jan 12, 2011 | 12:06 AM
powerstoked!'s Avatar
powerstoked!
Told you to heat that motor up!!! Haha I wasn't lyin
Old Jan 12, 2011 | 12:09 AM
ManicMike's Avatar
ManicMike
Theres your problem brotha.. Your not getting enough fuel. No fuel = no heat, no heat = no boost.
Old Jan 12, 2011 | 12:14 AM
powerstoked!
Didn't you say that you bought new sticks? Lets put them ****s in already and check your fuel pressure with the new sticks in. You got about 100k on your thermostat too, replace them ****s so the motor can warm up some and we might be in business
Old Jan 12, 2011 | 12:54 AM
deceptichop
Dave, thank you very much for your reply. I have an upgraded downpipe to 2.25" out the back to a straight pipe. I know its not the mighty 3", put its the best I can do with my factory housing. And the fuel is not turned up, the IP is still a virgin
ManicMike- Thank you as well for your reply. Ya man, looks like plain and simple.
Brian- Correct, I got the new sticks, IP, pyro, and intercooler. I was more excited then the first time i ever boned
Then unfortunately, last week, I had to sell them all I have been devastated yo. I came across some tough $$$ times of late, but will be back and ready to attack VERY soon. And yes, you have mentioned the stat
Old Jan 12, 2011 | 12:43 PM
tecgod13's Avatar
tecgod13
My truck has ~201K on original pump and injectors. Last winter I put a ATS 093 kit on with the 3" downpipe connected to a 3.5" exhaust (with muffler) out of a powerstroke. Stock intake as well. I average from 5-7 PSI on the highway when unloaded. I'm not loaded often, and even then, the max I've seen is maybe 9 PSI. When I installed the turbo, I played with the wastegate a little with a brake bleeder vacuum/air pump. I don't remember what it was stock, but I did adjust it slightly higher, but doubt it gets close to those levels.
I'm pretty sure my problem is worn out pump and injectors, but since it still runs fine, I can't afford to replace them at this time. I was contemplating wrapping the up-pipe in header wrap, but don't know how much I'd need, and its not as cheap as I'd like either.
I'm just throwing this to compare my experience with yours. I had wondered why mine didn't perform like others, but have come to the realization that I need to put more $$ into the truck. The turbo did help though.
Old Jan 12, 2011 | 07:29 PM
Coalroller's Avatar
Coalroller
just driving around and even on the highway i only run about 2-4 but the second i put the hammer down empty or hit a hill loaded ill hit 12-15
also i have 178k on my original pump (turned up though) and injectors, smashed down pipe to open exhaust and custom intake
Old Jan 12, 2011 | 08:37 PM
Sycostang67's Avatar
Sycostang67
You are driving the truck to get a boost reading and not just revving the motor in the driveway? I can hit 5psi sitting still but can hit 12psi screaming down the road.
Old Jan 12, 2011 | 08:41 PM
joe f350's Avatar
joe f350
yea he driveing i was with him when we adjjusted the rod
Old Jan 12, 2011 | 09:53 PM
rodneywar's Avatar
rodneywar
same here and i have the crushed dp i can go more but i invested too much in the motor to pop a head gasket and its my dd so no downtime allowed
Old Jan 14, 2011 | 11:09 PM
Sycostang67
Is the pump turned up at all? I'd closely inspect all the connections for signs of soot(easier to spot if turned up a few flats). Check the manifolds for cracks, the gaskets and the U-pipe connections. After I fixed all my leaks, I was amazed how much quicker I could build boost. If it still doesn't work for you than you probably dont have enough fuel.
snakedoc
Apr 5, 2013 02:43 PM
nossliw
43
Jul 15, 2012 12:13 PM
JonathanN
Mar 14, 2012 02:48 PM
a64armt
6.4L Power Stroke Diesel
16
May 10, 2009 09:18 AM
muddrag1
Oct 31, 2008 01:40 PM
