1978 - 1996 Big Bronco
transfer case front shaft leak
Old Jan 11, 2011 | 06:17 PM
Black Ford XLT's Avatar
Black Ford XLT
Need a little adive before i delve into this project(yes i knows it not a bronco )1985 f-150 4 speed (granny gear)4x4 300I 6.After driving around in ice and snow i have noticed a sizable leak and seems to be coming from my front shaft on the transfer case (ATF fluid).What does it take to replace this seal. Transfer case have to be removed? Yoke nut have to be removed? All help appreciated Thanks TR
Old Jan 11, 2011 | 06:51 PM
cOpE!'s Avatar
cOpE!
Im about to do mine because since ive moved to a cold location, mine leaks too. Ill probly get to it this week and let you know.
Old Feb 2, 2011 | 08:14 AM
Joseph69's Avatar
Joseph69
The hardest part of replacing the seal is removing the yoke nut. I believe it is a 1 1/4 or 1 1/8 inch nut. I put a jack handle(pipe) where the u-joint cap sits and tightened the u-bolt around it to keep the yoke from spinning. Then slide off the yoke, remove the seal and slap another one in place. There is a star looking rubber washer behind the nut, I just reused it.
Black Ford XLT
Jan 11, 2011 07:05 PM
FX4dude
2004 - 2008 F150
Jan 25, 2008 06:59 PM
jd_boggs
Jul 13, 2006 07:57 AM
t-roy
Nov 10, 2005 09:36 AM
