Whats a good frame
Old Jan 12, 2011 | 10:42 AM
fordman75's Avatar
fordman75
He pretty much said everything about the truck in the other vids.
It's on a shortened 78 F150 4x4 chassis. It has a 351M ( with compression bump, mild cam, edelbrock performer intake, He said it had an edelbrock carb but it's actually a Carter Comp 9000 series ) with a C6, Dana 44 front diff, 9" rear, 3.50 gears. A "Custom" body lift to clear the frame. The tires are 33"x14.5"x15". Fenderwell headers, dual 3" exhaust, Edelbrock Mufflers, Dodge dakota seat, a mix of autometer and some other type of gauge.
Old Jan 12, 2011 | 01:51 PM
61hawk's Avatar
61hawk
They wont let use run a truck on the road with tires sticking out like that. So Im lookinmg into bronco axles Did bronco have coil spring suspenion in the front
Old Jan 12, 2011 | 02:22 PM
fordman75's Avatar
fordman75
Yes all the Broncos had coil spring front suspension with radius arms. You can adapt this set up to your stock frame which would take some fabrication. Or you can cut the radius arm mounting tabs off and weld on some leaf spring perches. This will let you run your stock type suspension like this guy did.
https://www.ford-trucks.com/forums/7...d-f-1-4x4.html
But you'll want to use the early Bronco 66-77 axles. The 78-79 Bronco is the same width as the 78 F150. And the 80 and newer has the TTB front axle that's too wide.
If you want to run the coil spring front suspension your best bet is to get either a complete drivable early Bronco donor truck or at least a complete early Bronco chassis. Then you will have all the brackets, spring and shock mounts, etc. so you can adapt them to your stock frame.
Pronk
Oct 11, 2013 08:42 PM
robbie42301
Aug 26, 2010 08:24 AM
seventyseven250
20
Jan 4, 2008 09:19 PM
kris bassett
Oct 2, 2006 08:10 PM
mrfusion70
May 22, 2003 07:08 PM
